Thread: Replaced front offside wheel bearing, but ABS connector does not fit
    Mar 2011
    Bedworth
    Vehicle : Vauxhall Signum
    Trim : Elegance
    Engine : 1.9 CDTi 120PS
    Year : 06
    Mileage : 115000
    Red face Replaced front offside wheel bearing, but ABS connector does not fit
    Hi all. Following the fitting of four new tyres (and only weeks after full laser alignment) I found I still had the following symptoms on my car:
    • Steering wheel wobble/judder at 60mph and above
    • Pulling to the right
    • Droning noise driving round left-hand bends in the road (not cornering at low speed)
    After reading a number of posts on this frankly fantastic forum, I opted to replace the front offside wheel bearing. After SIX HOURS sat on the pavement outside the house today (OK so I take things slowly) I finally got the new one fitted. I took it for a test drive and to my relief the juddering has stopped, the car sits in a straight line, and there is no droning or vibration when driving round left- or right-hand bends.
    Only problem is, the wheel bearing kit I got from Euro Car Parts seems to have a different ABS sensor connector to the one I took off the car. The electrical contacts in the original sensor are two very small bore metal tubes which fit over pins in the car's connector. The ABS sensor on the new wheel bearing has two flat metal contacts.
    I found a thread regarding a similar issue, but my car does not have a sport button (that is, no IDS) and unlike in that thread there is no way at all that the ABS sensor connector on the new wheel bearing would fit in the car's connector.
    Does anyone have any advice on what to do?
    I've not yet tried to connect (using crocodile clips) the pins of the new connector to the car, just in case it breaks anything. What if I completely disassembled the swivel hub again and attempted to replace the new ABS sensor with the original one? Is that likely to work?
    Thanks for your time! (And sorry for the long post - I'm just posting as much info as possible should anyone else have similar symptoms to mine.)
    Chris
    Administrator plasma's Avatar
    On the Forum
    408 Post(s)
    Engine : 150
    Mileage : 74000
    you need the wheel bearing for IDS+ cars even though u dont have it, they changed the design around 2005'ish and all cars since require the type for IDS+
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    First I'd try contacting Ecp incase they can supply you with the correct one.
    If not it connect a multimeter on voltage ac an spin the wheel to confirm sensor reads ok.
    I would then carefully dismantle the plug from old sensor and new sensor an swap the wires over.
    As I think dismantling the swivel an replacing the actual sensor would be more hassle as you would need to find out what the correct air gap etc is
    Mar 2011
    Bedworth
    Trim : Elegance
    Year : 06
    Mileage : 115000
    Thanks guys
    I don't see how you're supposed to know these sort of things before ordering! Being a bit of a novice with all this, I never even considered that the connector might be different!
    I tried spinning the wheel earlier with a multimeter displaying DC voltage and DC current, but I didn't think to try AC. I will try the multimeter again and if I get a reading, I'll see whether the ABS light comes on when the sensor is connected via crocodile clips.
    Chris
    Mar 2011
    Bedworth
    Trim : Elegance
    Year : 06
    Mileage : 115000
    Tried the multimeter again and found that it automatically detected AC or DC, and it still didn't register anything.
    But I connected the pins of the ABS sensor to the pins on the car's connector using crocodile clips and upon starting the engine the ABS light went out as normal. So it seems I just need to chop off the new connector and refit the old one.
    Thanks both for your input!
  1. Tie rod and front wheel bearing!!!
    By scotty82 in forum Suspension, Wheels & Brakes
    Last Post: 30th March 2012, 19:04
  2. front wheel bearing
    By paulb70 in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2011, 20:15
  3. Front wheel bearing/hub
    By daviek in forum Parts for sale
    Last Post: 9th April 2010, 16:55
vauxhall signum wheel bearing plug connector
fitting a wheel bearing to vauxhall vectra c
