Thread: Brake Pad Wear Sensors
    May 2012
    Devon
    Default Brake Pad Wear Sensors
    Hi all,
    I changed the pads and discs on my Vectra C last weekend and noticed that on the near side the wear indicator was just a loose frayed bit of wire swinging in the breeze and that the off side was completely missing from the connector on the leg.
    I have now got new wear sensors to fit but don't know which way they sit in the pads.
    On the pad end of the sensor there is a plastic block with one side flat and the other side has a raised, almost 'T' shaped piece.
    Which of these sides faces the disc?
    Any help would be appreciated.
    Regards..,
    wirral
    49 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    The raised piece faces the disc
    May 2012
    Devon
    Thank you.
    May 2012
    Devon
    I found out why I couldn't see a wear indicator at all on the off side, there isn't one fitted.
    Not to worry, I now have a spare.
  1. brake pad wear sensors?
    By marwen in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2011, 12:01
  2. Brake Wear Sensors?
    By Danger_MouseUK in forum Handling & Braking
    Last Post: 23rd May 2011, 18:33
  3. Brake wear sensors.
    By fastcarmanaic in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2010, 23:36
  4. Brake Pad Wear Indicator
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 10th September 2007, 19:51
  5. pad wear sensors
    By hagga in forum Suspension, Wheels & Brakes
    Last Post: 9th May 2007, 21:19
