Results 1 to 10 of 17
Thread: Swirl bar problem
    Regular Member nicj's Avatar
    northumberland
    Vehicle : Cdti150
    Trim : Sri
    Year : 06
    Default Swirl bar problem
    Noticed the swirl bar has came off the vectra (1.9 cdti 150) The previous owner had the revised manifold put on. As far as I can gather i have 3 options
    1) Do a DIY repair
    2) Get it replaced/repaired professionally
    3) Drive it into a river
    Do you think it would be wise to try a DIY fix first or wll it
    Need replaced professionally at some point anyway?
    Jan 2012
    Gloucestershire
    Cheapest and quickest is to attempt to glue the swirl flaps open. Some have re-attached the bar with a few mods, but I've no idea how successful this has been. I eventually got the manifold and swirls replaced on my car and may now blank the EGR to prevent the gunk building up inside the manifold destroying the swirls again.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Just out of interest how long did the revised manifold last? I had mine done last year I also blanked my egr.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Glue them open Nic. Mine's been glued open for months now and the car still drives like new. I've a thread on here called "CDTi 150 Swirl Bar". PM me if you need a hand
    ---Sent from my iPhone 4 using Forum Runner.
    northumberland
    Vehicle : Cdti150
    Trim : Sri
    Year : 06
    Quote Originally Posted by dan danz View Post
    At a guess around a year and a half! 35k ish miles
    gwent
    I got a new manifold and the gaskets to go with it throttle body gasket egr gaskets and manifold gasket will be up for sale soon as I sold my vectra and brought a insignia
    West
    As long as the egr is blanked the manifold will be fine
    Quote Originally Posted by tony-1977 View Post
    Glue them open Nic. Mine's been glued open for months now and the car still drives like new. I've a thread on here called "CDTi 150 Swirl Bar". PM me if you need a hand .
    As Tony said... bonding them open & unplugging the egr is the best option, mine has been good for over 20k bonded & i just plug the egr back in for the mot.
    northumberland
    Vehicle : Cdti150
    Trim : Sri
    Year : 06
    Thanks guys I will do a DIY job (that should really read "I will bribe somebody to do it for me") : )
    N Ireland
    Whats the best way of cleaning/prepping that area around those swirl valves and what would be the best glue to use?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by naut1que
    Carb cleaner to clean the area. I used evostick liquid metal to bond mine :-)
  1. Potential swirl problem
    By Lito in forum Engine & Drivetrain
    Last Post: 12th August 2012, 09:36
  2. Swirl flaps problem i think
    By srinav in forum Engine & Drivetrain
    Last Post: 30th July 2011, 23:41
  3. swirl actuator problem
    By ziggi in forum Engine & Drivetrain
    Last Post: 30th September 2009, 03:34
  4. Swirl Actuator Problem... or not?!
    By djr69uk in forum Engine & Drivetrain
    Last Post: 2nd May 2009, 21:18
  5. Swirl Problem?!?!
    By Poma in forum Engine & Drivetrain
    Last Post: 25th February 2008, 22:23
