Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Fuel Filter
    Default Fuel Filter
    Just had a heated argument at my local VX dealership, and they are going to investigate
    I ordered a Fuel Filter, based on the part number from the previous service
    Removed it yesterday to find the part was completely different and fitted the new part
    This suggests the Fuel Filter was not replaced at the previous service, so the previously fitted one had in fact done 40K miles (two years)
    This older Fuel Filter is the OE part
    93185604 (has the part number stamped on the top, manufactured by Bosch, and has strips between the top and bottom of the canister)
    The new Fuel Filter is the After Market part
    93190458 (this has a paper appearance)
    This now explains the difference I had noted
    The OE part is in fact capable of coping with 30K miles
    The reason I noted the difference is that the dealership had not changed it!
    I still have my doubts about the After Market part, so would not exceed 10K miles, as many have found already
    There is virtually no difference in cost, so I would recommend using :
    93185604
    May 2012
    NW UK
    Thanks for the info. Definitely noted for future reference.
    Billion times easier to change than the 1.9 filter too...
    Quote Originally Posted by Penfold101 View Post
    Yes, I replaced mine and the engine started straight away, then after about 40 seconds cut out which I knew it would do as the air passed from the canister
    It took about eight complete attempts to restart, thought "Oh no, what now" as I made the final attempt and noted the battery was starting to struggle to turn the engine over
    I then let the engine idle for about 30 seconds, just to make sure
    A new Fuel Filter is now available specifically for the Y30DT and Z30DT
    95507489
    Mine was fitted last week and is a vast improvement over the other two versions
    However, note this is still limited to 10K miles / 1 year so be aware of this
    RO - all of South UK jaqubek's Avatar
    Sep 2011
    london
    17 Post(s)
    2 Thread(s)
    Vehicle : Vectra C Estate
    Engine : v6 3.0cdti
    Thats why I hate stealers and do my service in independent garage.I can stay and watch and be sure that all parts are fitted
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    TBH its really the trouble with these canister style filters, virtually no way of marking them. Other than opening them up and placing something inside, or opening them up after the service. At least in the past you could scratch a mark into the old types.
    Quote Originally Posted by Das View Post
    You can with these too, imprint the date it was inserted on to the top
    It's easier with the OE one as the top is metallic
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I agree oil filters are same that's why I right in paint pen on top so customers at least see a date so they believe its been done
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 Vtec
    Mileage : 64500
    Yes but that's reliant on the mechanic doing it, and the customer then opening them up to have a look, both almost highly unlikely to happen.
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. Fuel filter help
    By wolvesdaz in forum Engine & Drivetrain
    Last Post: 4th March 2011, 10:47
  3. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  4. fuel filter
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2007, 23:27
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
