Results 1 to 10 of 27
Thread: Problems getting worse.... Could be the end of the Vectra :(
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    Exclamation Problems getting worse.... Could be the end of the Vectra :(
    The other day I posted about a clunking noise everytime i pressed or released the accelerator coming from the front left of the car.
    Well, on the way home from work yesterday, from the same area, I had the normal clunking, but on occasion there was a grinding sound as if a belt is slipping from that area or as if a toothed sprocket of some kind was slipping.
    Any ideas what it could be? Gear changes are fine and clutch appears to be working perfectly. This is only happening on pressing and releasing the accelerator.
    Any help greatly appreciated.
    The car is a 2.2 DTI 2002.
    Russ
    Check the wheel bolts and the brakes are all done up fully mate, and the driveshaft isn't wobbling about...
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Possible gearbox / engine mount?
    Sounds like a worn driveshaft or cv joint to me.
    Mar 2007
    Grimsby, Lincs.
    Would that cause the horrible slipping sound I heard whilst driving?
    Are they cheap to replace?
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I woulf follow the advice of checking everythings nice n tight first. Jack it up,use a set of axle stands and have a look see..cant hurt n may just help to locate the fault.
    Cv joints etc are easy enough to replace if you have the tools and confidence.
    Mar 2007
    Grimsby, Lincs.
    Can a driveshaft slip whilst car in drive?
    Mar 2007
    Grimsby, Lincs.
    And surely the driveshaft would have been noticed on the recent mot
    Engine : 1.9 CDTi
    Yes the drive shaft can slip on its splines if worn and no it wouldn't have been picked up on an MOT as its not an MOT item apart from split CV boots.
    When was it last serviced and what was checked when it first started t make the noise?
    Mar 2007
    Grimsby, Lincs.
    Quote Originally Posted by lee gsi View Post
    Nothing has been checked yet. Was serviced about a year ago and had the inner CV boots replaced a week ago just before MOT.
    Would the driveshaft slipping make such a horrendous noise that can be heard in the car? This was mainly happening uphill.
  1. White smoke getting worse and worse
    By alphabravo in forum Vectra C / Signum Troubleshooting
    Last Post: 19th March 2011, 01:04
  2. Starting problems getting worse!! help!!
    By tony750cc in forum Vectra C / Signum Troubleshooting
    Last Post: 18th February 2010, 22:49
  3. This year couldn't get any worse (i bought stolen vectra....)
    By lewisboss777 in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2009, 18:15
  4. Its getting worse..........
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2009, 18:23
  5. Bad to worse!!!!!!!
    By Caterman in forum General Chat
    Last Post: 25th December 2007, 06:52
