Thread: Vectra C 1.8 idle
    Regular Member damers2000's Avatar
    Aug 2010
    Pontefract
    Default Vectra C 1.8 idle
    Hi all, my brother recently purchased a 56 plate Vectra 1.8.
    The idle seems very low and the rev needle seems to fluctuate and isn't steady, any ideas what we should be checking \ changing first or is this normal?
    My CDTI idles at 900 but with it being diesel not sure its comparable anyway
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    has engine management light come at all ???
    Aug 2010
    Pontefract
    no engine light on so maybe there isn't an issue, I don't know.
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    throttle body may need cleaning or somthing along those lines
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    I agree, if no warning lights throttle body most likely needs removing and cleaning. My z18xe idles at 800, not sure if the z18xer is different or not though.
    Aug 2010
    Pontefract
    ok cheers, we'll have a look at that first and take it from there. if the cdti throttle body is anything to go by its probably filthy
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    Dunno if it helps but I had to clean out the breather from the crankcase to the throttle body it was rock solid blocked with oil
    Aug 2010
    Pontefract
    thanks for the feedback
    just one thing, how do i go about finding out the engine code on his car? It's a facelift 55 plate 1.8
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Z18XE
    Z18XER
    Aug 2010
    Pontefract
    thanks for that DasArab! He's got the Z18XE, has this engine got the egr valve do you know?
  1. Vectra C 1.8 SRi Misfire when idle? HELP PLEASE?
    By shaine415 in forum Engine & Drivetrain
    Last Post: 25th February 2012, 15:52
  2. vectra 1.9 idle issue
    By robsveccycdti in forum Engine & Drivetrain
    Last Post: 5th March 2011, 19:31
  3. 2.0 turbo vectra low idle maybe misfire??????
    By vectra100turbo in forum Engine & Drivetrain
    Last Post: 1st February 2011, 17:36
  4. Replies: 4
    Last Post: 31st July 2008, 15:29
  5. Vectra 2003 V6 3.2 Idle problem
    By joseantoniovalle in forum Introduce yourself.
    Last Post: 18th August 2006, 16:23
