Results 1 to 10 of 11
Thread: Dead battery ?
    Jun 2012
    Midlands
    Default Dead battery ?
    Hi all,just bought my vectra c 1.9 cdti 150 about a month ago,bought off my dad who had it from new,its a 2007.anyhows when i bought it it had ecu light on that was down to egr valve so cleaned it all out and all was fine,took it to devon and done over 1000 miles no probs till this evening,i left work and it started ok drove home about 6 miles no probs.when come onto my drive i turned it off but needed to move it back a bit,tried to start it but it wouldnt ! Just turns over a bit then does that click click click noise,weird when ive drove home with no troubles.noticed the green light has gone from battery top too.
    Now i know it could be battery or alternator but as im a newb with vectras i wondered if theres a common fault that i should know about or any suggestions from you guys.many thanks and sorry my first post is asking for help,carl.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    what mileage has the car done ?
    here are a few threads that may help
    http://www.vectra-c.com/forum/search...earchid=168688
    Full Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    9 Post(s)
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    do you have a multimeter? if you do, get the car jump started, with the engine running pop the multimeter across the battery and measure the output, a correctly functioning alternator should give you a measurement of 14v, any higher/lower and the alternator is ******ed! failing that run the engine, turn your lights on, and give the engine a few rev, if your lights go brighter with revs applied but dim when taken off that is also an indication of your alternator being faulty. if the alternator is reading 14v or your lights are steady its your battery failing to hold its charge, they can be slow charged to full fuctionality but its usually better just to replace! hope this helps!
    Jun 2012
    Midlands
    Thanks for quick replys folks.
    The car has done 106 k BUT almost all motorway miles and looks mint in and out ! I work in a body shop so if i can get it jumped i will get multimeter on it,does it also need amps tested on it too ? Just baffled as i have used it loads in 4 weeks and gone to devon 600 mile round trip and drove home then dies on me.weird.
    May 2012
    9 Post(s)
    Trim : Exclusiv
    nah mate just the voltage will do, batteries are unreliable things at the best of times.
    Jun 2012
    Midlands
    Ok mate cheers,just hope its not alternator as they are mega dough arent they ?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    a bit more info and prices post 17
    http://www.vectra-c.com/forum/showth...ght=alternator
    i hope its not your alternator hopefully just the battery
    Jun 2012
    Midlands
    Quote Originally Posted by vectra ste View Post
    i hope so too mate.
    Not had any battery light on at all either ?
    Where in brum you from mate ? I work in sheldon/solihull.
    Jun 2012
    Midlands
    Well i forgot my volt meter when i came from work today so used my jump pack,started first time,but when i rev it i get a whinning type noise from alternator area,then when i remove jump pack from terminals i get a battery light and then the steering wheel and exclamation mark in yellow even tho its still running,i fear its the alternator but will need to confirm with volts meter.any ideas where i can get a new one from thats not gonna cost the earth and is it much of a job to change ? Many thanks,carl.
    Jun 2012
    Midlands
    confused No sat nav now
    Hi folks,im back again.got the alternator replaced today and all is well till i tried to use sat nav ! The radio is ok but no sat nav,it wont eject or load as when ignition is turned on you can hear the disc spinning/loading normally,but im not getting anything.i have tried disconecting battery again but still nothing ! Any ideas please thanks.
  1. Help: Dead battery won't jumpstart
    By Envy in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2011, 06:40
  2. Battery dead
    By trublu24 in forum The 'Off Topic' room
    Last Post: 24th March 2009, 22:00
  3. Dead battery
    By Morephun in forum Engine & Drivetrain
    Last Post: 23rd November 2008, 13:48
  4. Is my battery going dead?
    By BlueRob in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2007, 21:28
  5. Dead Battery
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2006, 12:35
