Results 1 to 10 of 15
Thread: 1.9cdti fuel pump leak
    May 2012
    Dundee
    Default 1.9cdti fuel pump leak
    Hi all,
    Traced a minor weep to the back of the fuel pump where the little housing bolts on.
    Some chump has stripped the head out of one of the bolts so wondering how easy it is to remove the pump, remove the housing seal it and fit new bolts?
    Can you get a new gasket for that bit?
    Thanks in advance
    May 2012
    Dundee
    Anyone know what's involved in removing pump please?
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Engine : Z19DTH
    Year : Nosey
    Cam belt removal, easily done on a drive with a jack supporting the engine from under neath because you have to remove the engine mount. Read up on the Cam belt change.
    May 2012
    Dundee
    Quote Originally Posted by nutron View Post
    I suspected the belt would need to come off, is there no tensioner to release it?
    Might have to wait til the weekend, was hoping to whip it off this afternoon :/
    thanks for the reply
    Jan 2012
    Silverstone village
    For the replacement gasket get the pump number and try calling helptoday
    http://www.helptoday.co.uk
    They should be able to get the bosch gasket if anyone can.
    May 2012
    Dundee
    I was gonna get the hylomar out but worth a look. Cheers
    May 2012
    Dundee
    Well thats 4 hours of my life I wont get back!
    Got it all stripped down to take the pump off - could I hell get the casting off to get access to the cambelt. Just had to put it back together again
    Fuming is an understatement!!
    Is there any knack to getting it off?
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    You mean the engine mount below the airbox?
    May 2012
    Dundee
    The engine side of the mount, which covers the cambelt tensioner
    Cheers
    Regular Member FatboySteve's Avatar
    May 2010
    Bedfordshire
    2 bolts underneath, and 3 on top. One of the bolts is covered by the aux tensioner, so you need to remove that. This will be the one holding you back!!
    The Cambelt doesn't actually have to come off, you can lock the pulley in place, and remove the pump i think ? Search for replacing Inlet Manifold, as it's the same procedure.
  1. 1.9cdti fuel filter housing leak ?
    By john1 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 18:41
  2. help fuel pump on 1.9cdti 150
    By dbgb25 in forum Engine & Drivetrain
    Last Post: 30th January 2012, 13:34
  3. 1.9cdti 16v fuel pump
    By paulcdti150 in forum Engine & Drivetrain
    Last Post: 15th September 2011, 02:48
  4. Fuel pump gear 1.9CDTI
    By jpimpao01 in forum Engine & Drivetrain
    Last Post: 18th April 2011, 19:18
  5. Fuel pump 1.9cdti 150
    By mark230678 in forum Parts for sale
    Last Post: 3rd July 2009, 21:42
