Thread: help with nav
    Regular Member vectra sri dan's Avatar
    Oct 2006
    newcastle-under-lyme
    Default help with nav
    my nav works fine in everyway other than the map no longer works .
    every time i try to turn the position map on it will not show on the screen
    this only happend since i had the head unit out . i have checked all the conections since amd tryed another disc but still no joy .
    everything elce works fine on the stereo and the nav will work fine just will not show the map on screen.
    if anyone could give me any idears it would be grate .
    thanks ppl
    [Ex]Admin Duncan's Avatar
    Which unit have you got? - so people can maybe give you a reply more easily.
    Feb 2006
    Dorset
    Have you plugged the display cable back in ?
    take it all out again and double check , what did you have it out for ?
    Feb 2006
    Dorset
    if its the car in the pic dunc it will be a cd70
    Oct 2006
    yes its a cd 70 had it out to fit a sub everything elce on the screen works fine cd text nav etc just not the map function will not show and just comes blank dark screen .
    all cables are in the back of unit had it out 3 times and re conected but still the same
    Feb 2006
    Dorset
    Strange one .... trip to the dealers then im afraid .
