Results 1 to 10 of 11
Thread: Heater Blower Motor - Bearing Replacement
    Nov 2009
    West Midlands
    Question Heater Blower Motor - Bearing Replacement
    Hi all,
    For a while now I have been getting a noise from the heater blower motor which sounds just like the bearings have gone.
    Have removed the motor this evening to see if I can remove the bearings but can't seem to get the fan part off the motor:
    Anyone help with how to detach the fan from the motor as don't want to pull it too much if it should unscrew etc?
    Also, can anyone suggest where I might be able to get replacement bearings or, at worse, a replacement motor?
    Thanks.
    Pete.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    I don't think you can repair them. Have you sprayed wd40 on it?
    Nov 2009
    West Midlands
    Only after I removed the unit did I realise I had run out of WD40 Will give that a go tomorrow. Was just wondering if anyone else had fixed one of these as seems such a waste of the part and money to spend £130+ on a whole new unit when it seems just a small part it bust!
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    If the fan is stiff you can blow the resistor.
    Nov 2009
    West Midlands
    That's already happened once but before it started making the noise. Want to get it sorted so I don't have to pay out for another resistor.
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Have you checked your scuttle isn't blocked because it broke my mates resister and fan bearings?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by pshankland View Post
    I would be a bit wary of using WD40 - its fine while it is fresh but I find after a few days it tends to dry out and turns into a lacquer - exactly what its lubrication is like when it gets to this state I don't know. I would be tempted to use one of the spray type greases you can get with the long extension spay tube to get access inside
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    thats the only problem with wd40, it works wonders, but once it evaporates noises start to return, but id never be without a can of wd40 - love the smell lol.
    Nov 2010
    East Midlands
    Trim : design
    Yea I must admit I like the smell of it so if you spray it in your heater fan - you will have that smell for weeks lol - its good as a freeing / releasing oil but as you say the it evaporates after a while and leaves a residue.
  1. Heater Blower Motor suddenly stopped
    By Snizzers in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2012, 22:58
  2. help heater blower motor
    By whitevanman in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2010, 01:27
  3. Zafira Heater/blower motor
    By glenboy in forum General Chat
    Last Post: 9th June 2010, 22:01
  4. Sqeeky heater/blower motor.
    By SNODDY70 in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2009, 23:05
bearing 05 blower central
vectra c blower motor
vectra c heater blower replacement bearings
https:www.vectra-c.comforumshowthread.php168608-Heater-Blower-Motor-Bearing-Replacement
car blower motor bearing
vectra heater motor
vectra c heater motor
how to remove vectra c heater blower motor
vauxhall vectra 2006 blower screeching
vectra c heater blower removal
vectra blower motor
vectra c squeaky heater fan
opel vectra heater fan
vectra c blower motor removal
05 vauxhall vectra heater fan replacement
how to remove heater blower vectra c
vectra c heater fan
how to lubricate bearings on heater blower vauxhall vectra 2005
vauxhall signum heater motor removal
heater motor bearings
vectra c heater blower squeaking
vauxhall vectra c heater motor squeaking
vectra c stiff heater blower
changing a vectra climate control blower
vectra heater motor what oil to lube
