Thread: 3500 rpm then limp mode 1.9 cdti
    Feb 2011
    ashford kent
    Default 3500 rpm then limp mode 1.9 cdti
    If i accelerate hard it will go into limp mode and spaner light comes on, can drive slowly through gears and do 80 -90 mph in 6th , Cleaned egr cleaned boost sencor, after checking forum tried to run engine hard in 4th now have a blown pipe from manifold to egr, have left it at a garage that i have not used before they seem to think that the glow plugs and the pipe may have been fractured was the cause of the limp home mode.
    The car has 167k and for the last 50k the swirl valves have been disconected (knackered) Will glow plugs cause the car to shut down 3 out of 4 where not working when removed
    Jan 2012
    Gloucestershire
    I assume that the split pipe is from the exhaust manifold to the EGR, as I don't think the 150 has a pipe between the EGR and inlet manifold. If it's split it needs replacing or blanking to eliminate this as the cause of the spanner light.
    Anyway, the symptoms you describe sound more like a vacuum hose leak to me (from what happened on my 120). Check the narrow rubber vacuum pipes first, particularly at connections and bends/elbows - I'm not sure where they are on the 150. A split can be difficult to see, so check thoroughly.
    As always though, get the error codes checked if you can as these will help the diagnosis.
    Feb 2011
    ashford kent
    Cheers will get them to check all pipes for splits, was conserened about changing glow plug as they are only used at start up so would they cause the power problem or are they just following their snap on diagnosti tool to the letter
    Jan 2012
    Gloucestershire
    Hmm, as you have a Signum, you probably have a DPF which would be why you ran it around in 4th gear I guess! The reason for this would be to trigger the regeneration cycle to clear the DPF, but if you managed to blow the exhaust manifold pipe to EGR, maybe the DPF is seriously blocked and the back pressure from the exhaust was enough to rupture a weak hose?! I've not heard of anyone blowing this pipe like this though.
    You need the fault codes read. If the garage have read the codes, ask for them. If not, you may be able to get the codes yourself using the pedal test (see the How2 on this site). I think P1901 is the usual code for a blocked DPF.
  1. Cdti limp mode???.
    By steve1312 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2012, 00:46
  2. cdti 150 cuts out to limp mode
    By toma69 in forum Engine & Drivetrain
    Last Post: 27th June 2010, 18:22
  3. Signum 1.9 CDTi limp mode
    By doublek500 in forum Engine & Drivetrain
    Last Post: 6th June 2010, 22:26
  4. Limp mode under acceleration - 3.0 CDTi
    By Celes in forum Engine & Drivetrain
    Last Post: 23rd December 2009, 01:41
  5. 1.9 cdti 150 limp mode
    By jeets in forum Introduce yourself.
    Last Post: 30th May 2009, 20:29
cdti limps out at 90 mph
astra 1.9 limp mode over 3500 rpm
vectra c 3500rpm limit
why is it when i accelerate hard my car going into limp mode insignia
