Thread: Coolant change
    Apr 2011
    essex
    Default Coolant change
    Decided to service the car today.
    Cabin, air , fuel (petrol splash in the eye!!), oil filters. Spark plugs, oil change and then finally coolant.
    I followed the how 2 and drained it using the bottom of the rad, then flushed it through, filled up a bit with water started it let it warm up then re-drain. I used the red long life stuff for vx. My z22se takes 7.1L so I put 1 ltr of red, 1 litre of water , 1 ltr of red then half way through the 2nd water it wouldn't go down? stopped it at the half way level then started it, let it warm up, nothing? so I took it for a drive nothing? and it still hasn't gone down. I put in about 3 and a half ltrs.
    Will there be some kind of blockage? when took it for a drive it went to normal 87ish and when I left it running the fans kicked in and went off as normal. What have I done wrong/ or broken
    Mileage : 000
    Might have an air lock. Put the heater on hot. Run it for s while. See if that helps. If not take the header tank cap off and run it for a while just ticking over. Hopefully that will remove the air lock.
    Jun 2011
    wolverhampton
    How much did u drain out?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    there is pretty much no way of getting what's around the block out(without removing the water pump), best bet is to remove the thermostat and the top hose from the radiator, then stick the hose in each end and keep flushing both ways until its crystal clear, reconnect everything add 3.5lt of antifreeze and top up with water. Run up until the engine reaches temp, with teh heater on hot, leave over night and top up with water accordingly. Test mixture is at at least -27 and drain/add antifreeze till you get where it needs to be.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    what he said
    but wear your wellies when its -27 lol
    Aug 2010
    Leeds
    Can't you drain the block is there not a bung? Thats a large bolt in the water jacket of the block.
    Why did you drain it was it over 10yrs old or weak?
    Apr 2011
    essex
    I've done both of the suggested ideas and it's still not gone down. At least 5L came out as I used a 5L container and I filled that plus a bit more. I'm guessing after emptied it the first time and then did the hose that water stayed in the main block? So I've got 7L in there but only 2L is coolant the rest water. What would you advise I do to correct it I've got 2L of coolant left.
    Aug 2010
    Leeds
    Test the strength you may be ok.
    If -25 or more bang on lets be honest it's never colder than -12 is it?
    South east
    Buy an anti-freeze mixture tester from Halfords, they're very cheap. It's like a pen or pippet, it sucks up a small amount of liquid from the expansion tank and you see how many "balloons" in the tester float upwards - that tells you if you have the right concentration or not.
    http://www.halfords.com/webapp/wcs/s...egoryId_255224
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Quote Originally Posted by Bigtee View Post
    I believe its not so much to do with frost protection but to provide optimum anti corrosive properties to the aluminium engine components.
  1. Coolant change
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2013, 10:58
  2. coolant change
    By nick6515 in forum Engine & Drivetrain
    Last Post: 24th November 2012, 15:38
  3. Coolant change
    By Corey in forum Vectra C / Signum Troubleshooting
    Last Post: 14th October 2012, 21:26
  4. Coolant Change
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 23:21
  5. Coolant change 2.0T?
    By mark1319 in forum Engine & Drivetrain
    Last Post: 19th December 2008, 01:28
