Results 1 to 10 of 19
Thread: Steering strange sensation
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default Steering strange sensation
    Hello everyone I have encountered a strange steering issue and I'm not to sure how to explain it I was travelling along today coming back from the gym at around 45-50 mph and I hit some divets in the road it felt like I had 4 wheel steering, so I did a little test I stayed at speed and twitched the steering wheel quite quick left to right fast and the back end felt like it wasn't attached to the car or the wheels on the from seemed to turn quicker than the steering wheel if that makes sense.
    I'm not sure if this has anything to do with it but I had a 4 wheel alignment done and the car drive great but the wheel was off to the left so I went to a friend and he took off the steering wheel and put it back on slightly to the right which corrected it, if you look at the back of the steering wheel with it removed vauxhall have made a groove for the steering wheel to be easy to align I have moved this slightly to the right can someone help me with this
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    I have been out in it again it feels like the front wheels are not connected to the steering wheel there is some play also in the wheel now I have checked underneath and there is no leakes and also the fluid is full has anyone got any ideas before I ask vauxhall to take a look
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Bump surely someone must have an idea or as this one stumped you all lol
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Maybe this might make more sense as I have been searching google, the car drives fine when driven normal say 30-40 mph but 50mph plus at speed it's noticeable i think something has suddenly failed as this has happened all of a sudden it's like when I turn the wheel left and right like I'm warming up my tyres it's like a delayed reaction the steering feels very light I don't think I have a power steering problem I'm hoping it's a damper failure has I'm changing them anyway I just hope it's not steering rack please someone advise me my car handles like a go kart
    Regular Member Das's Avatar
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Any knocking from the front or rear? Rear upper control arm bushes or front drop links maybe?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 130000
    what mileage is your 2005 car on
    the reason i ask is beacause i have a similar problem i recently went for an mot and it came back with
    nearside drag link end ball joint has slight play { 2.2.b.1f}
    this may be related
    my mileage is on 65000
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Ok my car is a late 2005 and is currently on 50700 miles I do have a very faint knock from front but this I think is my arb bushes I do however have a his from drivers side front when going over a speed bump which makes me think it's my shock, I have recently had 4 new tyres has the rear tyres had worn bad on the inside edge so after having new tyres I had it laser aligned on an hunter machine
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Sounds to me like the wheel toe is out.
    Or ackermans angle is incorrect. Ie theyve made the adjustment to just 1 wheel
    you need to get it in the air an count the threads on each track rod
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    the tracking is still out fella you shouldnt have to remove the steering wheel to put the wheel straight . also have you checked the clamp bolt at the end of the steering coloum as there is a thread on here somwhere about this working loose
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    I have ordered my new shocks aready and waiting for them to come ill have this fitted and have my wheel put back on the line then get it re aligned I'll aso have all bushes checked to be safe anything that needs replacing wi get done
  1. For Sale: iphone 3gs 16 gb and htc sensation
    By DAVIDD88 in forum General items for sale
    Last Post: 23rd October 2012, 16:28
  2. For Sale: htc sensation 16 gig
    By stuart bigboy in forum General items for sale
    Last Post: 4th August 2012, 19:23
  3. Help!! Power steering making strange noise
    By philgst in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2011, 22:19
  4. Strange sensation under braking
    By dolf.peeters in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2010, 11:47
steering in my 2005 vectra strange
