Results 1 to 10 of 13
Thread: help please.
    Regular Member Legion84's Avatar
    Jan 2012
    Stockton On Tees
    Default help please.
    Sorry to kind of repost I bumped my topic about engine been sluggish, I've cleaned the manifold put it back together the car will turn and turn but it won't fire up any ideas, I'm guessing the fuel lines from the injector any advice please
    Jan 2012
    Stockton On Tees
    On a side note I can hear pressure going up to the top left vacum near air box after trying to turnover the car? Like a hiss anyone?
    Nottinghamshire
    If it's a DTI, the fuel will have run back towards the tank if you've opened the fuel pipes and there's no electric pump in the tank to push it back towards the engine.
    You will need to bleed/prime it before it will start to avoid damaging the high pressure fuel pump. Do a search on here - there's information on various ways of doing it.
    Nottinghamshire
    Just found your other posts - you have a DTi so the above does apply if you've opened the fuel lines.
    PS - probably better to keep to one post per topic / issue otherwise it gets very fragmented, and anyone who has contributed to one thread won't get email notification of changes to the others...
    Jan 2012
    Stockton On Tees
    Thanks James, sounds exactly like my problem air in the system, could you tell me which pipe I will need to bleed and what I could use as I don't have a pump to do this, I hear you can do it by loosen the nuts then when fuel comes out tighten them one by one but I really would like to suck air or pump fuel through as its hard to get in to the nuts with spanner
    Jan 2012
    Stockton On Tees
    pics included, can anyone tell me which way the piming bulb will need to suck and on which line, thanks guys IMAG0015.jpgIMAG0016.jpg
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Loosen injector nuts one at a time, failing that get someone to tow start you
    Irmscher Insignia CDTI 130
    Jan 2012
    Stockton On Tees
    do you know anything about using a prima bulb to do this ?
    Jan 2012
    Stockton On Tees
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Haven't a clue mate, when my old dti wouldn't start the guy came out and sprayed brake and clutch cleaner into airtake and she eventually started,but if i was you i would get someone to crank over while you loosen injectors until diesel squirts out,do one at a time.
