Results 1 to 10 of 14
Thread: Steering wheel warning light , no power steering!
    Jul 2012
    Sheffield
    Default Steering wheel warning light , no power steering!
    Last night i nipped out to tesco , spent an hour in tesco.
    Got back in my car fired it up , and the light was on for the steering wheel and the power steering did not work, AT ALL
    It was so incredibly hard to turn the steering.
    about 10 meters away i turned the engine off and back on and the power steering was back! with no light no nothing and works brilliantly.
    Ive started and stopped around 6 times today and its been fine.
    Any idea what the cause could have been?
    Jul 2011
    UK
    Year : 06
    Sounds like power steering pump failing
    Jul 2012
    Sheffield
    Why would it only happen once ? And go back to normal once I restarted it
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Could be your pump - more likely to be your alternator - first of all get your alternator and battery checked - also check the connections to the pump and your p/steering fluid level.
    May 2006
    scotland
    Yep as above, could be an alternator glitch or on its way out.
    Regular Member sscully's Avatar
    Jul 2011
    WALLASEY
    Vehicle : Vectra C Facelift
    Trim : SRI
    Engine : 1.9 Diesel
    Mileage : 89000
    Have you checked your fluid levels just in case it could be an easy fix. Think if it was alternator the battery light would be on.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by sscully View Post
    Battery light never came on when mine went just got the steering wheel with spanner light on dash - only lost p/steering for a few seconds and then would recover - obviously an intermittent fault - replaced alternator and fine. As I said above check fluid level and connections to pump first off.
    Jul 2012
    Sheffield
    Had a go at checking the p.steering fluid level , Couldnt find it.
    Apparently its under the wheel arch ? no idea why!
    Ill try to find it again when the weathers a bit better.
    Thanks all , will keep you informed
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Mine is below the fuel filter, between the filter and steering rack. Nice and easy access for filling - NOT
    btw 1.9 8v facelift
    Jul 2011
    UK
    Year : 06
    Facelift under the fuel filter looks like a milk bottle
    Pre face in the wing wheel arch
  1. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  2. power steering warning light!
    By mick 1986 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2010, 20:36
  3. Power steering warning light
    By neil1194 in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2009, 09:53
  4. Power Steering Warning Light - Ugh!
    By Leviathan in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2008, 17:25
  5. Power steering warning light !!!!!!!!
    By Scott_C in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2007, 19:00
vauxhall vectra power steering light on and no power steering
vauxhall vectra steering wheel light on dash
vauxhall vectra warning lights steering wheel
warning lights on vectra c 1.9 cdti power steering
1.9 cdti steering wheel light heavy steering
vectra 1.9 cdti steering wheel warning light
vectra c power steering warning light
vectra sri power steering warning light
vectra 07 steering wheel light on and its heavy to syeer
power steering light vectra sri
warning light on signum steering
2005 vec c no power steering and wheel warning light on clocks
power steering light vauxhall vectra
signum steering wheel on warning
steering light in vauxhall vectra sri
06 vauxhall Vectra steering wheel symbol on dash
