Results 1 to 2 of 2
Thread: Astra gear stick
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    Default Astra gear stick
    I guys... Sorry for the questions regarding this ... Right, I have an Astra h gearstick which is the the knob, the gaitor and the shaft with 2 plastic balls on it, when I lift up the gaitor in my vectra to have a look, I can see the 4 torx screws that I need to undo, what I don't understand is this.. When I undo the 4 torx screws to release the black square frame thing, does my Astra donor gearstick then have to go into the black frame thing, and will it fit.... The Astra knob is a 5 speed with reverse gear in the same place as the vectra one.. So it is like for like iykwim...... Any help greatly appreciated,,, I'm worried that I'll take it all apart and something will go pear shaped.... Or my donor one won't fit
    Sent from my iPhone using Forum Runner
    Jul 2011
    UK
    Year : 06
    If I remember correctly the Astra gear stick should have the plastic base although i can't remember if the base comes off the vectra stick but if it does then yer swap it over not sure on the 5 speed but u have to disconnect the cable aswell and connect the Astra connected to ur cable
  1. astra gear stick help
    Last Post: 24th March 2012, 16:52
  2. My XP2 with Astra gear stick
    By Mopar Man in forum Quick Photo Album
    Last Post: 21st March 2012, 19:51
  3. astra gear stick
    By marc vectra sri in forum Styling
    Last Post: 12th March 2012, 18:24
  4. Update on Astra VXR gear stick
    By pipamish in forum Styling
    Last Post: 21st December 2011, 21:14
  5. Will an astra h gear stick fit?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2010, 17:30
