Results 1 to 10 of 14
Thread: The hand brake adjuster.
    Aug 2010
    Leeds
    Default The hand brake adjuster.
    Where is it?
    How many clicks do you prefer?
    I have 4-5 with new pads fitted id like max of 3 and then id like it to pull to 3 if you understand.
    58 plate cdti.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Its none adjustable mate.
    Barrow In Furness, Cumbria
    I believe you can adjust it by removing the rear ashtray?
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by Chris SRi View Post
    Are you sure, its self adjusting. Ive never seen an adjustment by the ashtray but happy to be shown otherwise.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    never seen an adjuster there either.
    Admin plasma's Avatar
    On the Forum
    310 Post(s)
    Engine : 150
    Mileage : 74000
    never seen the ashtray adjusting the handbrake before? On the old veccy b's you could remove the pop up cover and adjust a nut on the cable. With the vectra if you remove the surroundings all you will see is an auto-adjuster, you can reset this and put this into 'transport' mode, and when you use the handbrake it takes it out of transport mode and activates the ratchet assembly which is self adjusting, thus if the handbrake is too high then either the calipers need winding in and then handbreak readjusting or one of the 3 sections of handbrake cables has stretched somewhat.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Yeah, the Vec 's were a doddle. Didn't even have to get dirty doing it!
    I've never tried this on the Vectra C, but knew I'd seen it somewhere.
    Regular Member Keif's Avatar
    In the Garage
    As Plasma says, It's NOT adjustable.
    It self adjusts, the only way to make it better is replace a possibly stretched Handbrake cable.
    http://www.vectra-c.com/forum/showth...01#post1540001
    Aug 2010
    Leeds
    Guys it holds fully loaded on a hill without putting in gear but it's always in 2nd.
    Thanks for the comments im just used to 3 clicks but as it works fine i'll live with it. Thanks again. Tony.
  1. Hand Brake
    By crispy007 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2013, 18:05
  2. hand brake?
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2010, 21:59
  3. Hand Brake Adjustment
    By scottymf in forum Suspension, Wheels & Brakes
    Last Post: 29th September 2008, 10:01
  4. hand brake
    By JATBOY in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2006, 07:32
  5. hand brake
    By murf2484 in forum Suspension, Wheels & Brakes
    Last Post: 18th June 2006, 11:36
vectra c handbrake adjuster
