Thread: Dash Board headlight bulb failure
    Ayrhire
    Default Dash Board headlight bulb failure
    Hi All,I have a 54 plate Signum 19.CDTi , which is due for its MOT, It is my understanding that from this year all dash warning lights are required to be working.On my dash when the headlights are on main beam the "GREEN headlight light" does not come on, The blue "full beam light" does.So I am presumming this is now an Mot failure.I understand that these dash units are sealed and that the lights are soldered LEDs and not replaceable bulbs, Does anyone on here know of a solution, short of fitting a whole new dash unit.Many ThanksStephen
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Don't think my pre-face Vectra had a dash light for sidelights / dips. Just main beams
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    All LEDs can be replaced and its not a sealed unit.
    You need someone near to you who can take the clocks out and use a soldering iron. Replacement LEDs are dead easy to come by but you normally have to buy in batches of at least 5 from most places.
    Hope this helps
    Edit may e you don't have that light option on your dash but really don't know about that. I'm sure someone will come along with the answer
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    When the lights are on main beam the blue light should be lit so it's correct operation
    Unless by main beam you mean dipped beam ( normal headlights?)
    Ayrhire
    HiI mean when normal headlights are on then the green light should come on but doesn't, with full beam the blue light comes on as normal.ThanksStephen.
    11 Post(s)
    Quote Originally Posted by srobertson1 View Post
    HiI mean when normal headlights are on then the green light should come on.
    Not on a 54 plate Vectra it won't. Your speedo lights don't come on until you put the headlights on. That is the indicator to tell you the headlights are on. The green light was fitted to newer Vectras as the speedo lights come on with the ignition, not the headlights, and the green light was to tell you the headlights are on because the speedo lights no longer gave a you an indication.
    That particular light isn't part of the MOT anyway as many cars don't have it fitted. i.e. it's not a standard light. Its also not a warning light, it's just a courtesy light.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    O right ok yeah as above that green light isn't their so don't worry
    I did notice this when I first got my vec
  1. Bulb failure light on dash - always on.
    By Dal5band in forum Bodywork & Interior
    Last Post: 15th December 2011, 14:23
  2. Bulb Failure in Dash
    By TheVoid in forum Electrical & ICE (including SatNav)
    Last Post: 10th May 2011, 15:50
  3. bulb failure warning light on dash
    By bigbill94 in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2010, 19:35
  4. dash board cut out
    By dax in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2008, 22:41
