Thread: vectra c drag link end ball joint
    Regular Member keggy77's Avatar
    Aug 2011
    Birmingham
    Vehicle : VECTRA C
    Trim : CLUB
    Engine : 1.8 16 V
    Mileage : 80,000
    confused vectra c drag link end ball joint
    can any body help just had an advisory for the n/s inner (rack) drag link end ball joint has slight play . never heard of one and dont know where it is. i know where the drop links are but not these drag links so i need some help any ideas anyone ? thanks
    Sep 2011
    West Yorkshire
    I too had the same advisery last year. They are basically the end of the track rod arms, with the ball joint relating to the part that connects the track arm to the hub and subsequently moves your wheel left and right. Easily identified by the threaded bar pertruding to your wheel from the steering rack, with the ball joint visible on the wheel end.
    Should be relatively cheap to replace, however I havent had them done as of yet.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    well how weird is that i had my mot test in march
    and came back with an advisory nearside drag link end ball joint has slight play 2.2.b.1f
    Aug 2011
    Birmingham
    Vehicle : VECTRA C
    Trim : CLUB
    Engine : 1.8 16 V
    Mileage : 80,000
    any ideas where these are mate need to change the n/s one are they the same as track rod ends ????? never heard of them before mate thanks kev !
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Drag link on a car? Never heard that someone needs to learn their steering parts
    I can only assume it refers to track rod end
    Aug 2011
    Birmingham
    Vehicle : VECTRA C
    Trim : CLUB
    Engine : 1.8 16 V
    Mileage : 80,000
    so why didnt the mot tester put n/s track rod end on the advisory so i knew what it was instead of 003 nearside inner (rack) drag link end ball joint has slight play [2.2.b1f] trying to confuse people like that ?
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    By the sounds of it it's actually the track rod not the ends, I've always known them as rack ends, it's the inner ball joint where it connects to the steering rack that has play.
    Can be a simple fix if you have the correct tools for the job and are able to track the car up afterwards
    Aug 2011
    Birmingham
    Vehicle : VECTRA C
    Trim : CLUB
    Engine : 1.8 16 V
    Mileage : 80,000
    hope it isnt the inner ball joint on the tie rod they are a nightmare to change done the o/s one last year a real pain in the arse to do might book it in at the garage and let them do it !
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    Quote Originally Posted by keggy77 View Post
    anyupdate yet
  1. spinning ball joint
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 7th August 2011, 21:09
  2. Ball joint issues
    By hothatch in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2011, 21:46
  3. failed MOT ARB Ball Joint
    By howieallstars in forum Handling & Braking
    Last Post: 15th November 2010, 16:50
  4. bottom ball joint
    By paulvectrac in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2010, 14:23
  5. drag link
    By delboy2028 in forum Suspension, Wheels & Brakes
    Last Post: 17th January 2010, 10:15
drag link arm vectra c
What does a drag link mean on a Vauxhall vectra
vectra c draglink
linkend
vectra drag link end ball joint
