Thread: Corsa c canbus or not ???
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    Default Corsa c canbus or not ???
    as the title says need to know if the corsa c on a 54 plate is canbus or not as im wanting to change the mrs stereo to a cd30 mp3.
    so do i need just the stereo and the code or do i need the stereo with a matching screen ???
    any info much appreciated
    cheers
    Paul
    Full Member coldo's Avatar
    Scotland
    Difficutlt to tell. I had a 2004 corsa which was ISO (half can bus) but I am sure Vauxchall changed all there line to full can bus arround 2004 on 54 plates...
    What radio does it have in it at present...? If it's a CDR 2005 then chances are it's half can bus and if it's CD30 then it's full can bus...
    You could take the radio out and chack the wiring plug... It will either be ISO (three plugs attached to the back fo the fitting cage) or fraquar (think that's what it's name is) which is a large quad lock block with the cables allattached in it...
    Good is your friend for this one...
    Scotland
    Oh and if its can bus then screen and radio will most likley be paired. is it's not then it's radio with a code but I am sure the CD30mp3 being can bus only will not work in a half canbus car...
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    there is a cd30 in there at the moment
    Scotland
    to me that means its full can bus... So screen and radio set should fit right in given they are paired to each other...
    Get that double checked but from what I know it should be the case!
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    ok mate thanks for the info
  1. Full Canbus - Half Canbus. Whats the difference?
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2013, 09:02
  2. canbus/non canbus HID kits
    By glovej in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 10:00
  3. half canbus to full canbus
    By MORGIE8153 in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2010, 17:26
  4. Whats the difference between a canbus car and a half canbus car
    By chuckleuk in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2010, 21:07
  5. Half CANbus/Full CANbus?
    By Ross DTi 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 12th September 2006, 20:13
can-bus corsa c
