Results 1 to 10 of 18
Thread: Will this stop my 501's strobing?
    Regular Member coldo's Avatar
    Scotland
    Default Will this stop my 501's strobing?
    I have fitted SMD 501 can bus compatible bulbs to my head lights and all is well with them excet for the fact they strobe due to the bulb checking system...
    I spotted these
    http://www.ebay.co.uk/itm/Load-Resis...item3f19b6cdb2
    Any ideas if this will fix the issue?
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    not seen these i fitted resistors to stop bulb error and worked fine not sure what these do but for £5 give them a go and post up your results m8
    Scotland
    ordered them this afternoon... Will let you all know how I get on.
    Trim : improving
    Year : 06
    diamond ,i hope they work as it will save me running mine through a relay
    Mar 2012
    Norway
    I hope they work for you, but as it only is resistors in the kit, I think it will still strobe...
    I think maybe a condensator in series with the power wire could be a fix, but I may be wrong.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Will top but error but they'll still flash as I solders my own resistors in.
    It need a capacitor in series with bulb to stop them
    Scotland
    Got them, fitted them and..... Made sod all difference.. Still strobing!
    I may try cutting the wires and splicing in a second bulb holder with glass 501's to see if that makes any difference...
    Thoughts on this folks?
    Mar 2012
    Norway
    Save yourself the work, its still gonna strobe.
    The only solution as I can see it is to put a capacitor in seriers with the power.
    I don't know which type or values to go for yet.
    Scotland
    I guess the other option is a session with Tech2 to turn off the check function for all the bulbs...
    I dont think Op Com can do that but Tech2 might be able to!
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    A low value resistor can fool the OBD in thinking it checks an incandescence bulb, but it has nothing to do with strobing.
    You can see the LEDs strobing because the check signal is too short to heat standard bulbs filaments enough to produce visible light, but LEDs have almost no inertia and respond immediatly, thus providing a visible flash of light.
    To overcome this problem, you'll have to insert some sort of signal delaying device so they light up only when the current is maintained for a while, I think at least more 1 second. I'm still working on this. BTW, there are some ready-made devices around aimed at HID that should work, such as these ones :
    http://www.ebay.co.uk/itm/1508261645...84.m1439.l2649
    But don't use the rubbish you cited, as they'll just heat a lot, plus your "can bus compatible" LED bulb obvioulsy have a much better electronic anti-error device included already.
    On the other hand there's absolutely nothing you can do with the Tech2 to stop the OBD from checking the sidelights bulbs. It can be done only for the low beam lights because they can be xenon from factory (and the flash from the check signal would destroy the xenon bulbs, as they don't like this at all).
  1. strobing led's
    By patch22 in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2017, 22:44
  2. Strobing LED's
    By rmg1 in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2012, 21:10
  3. wiring angel eyes to stop strobing?
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2012, 18:43
  4. stopping strobing idea
    By mrk in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2012, 12:16
  5. LED 501's
    By dwayneoo12 in forum Styling
    Last Post: 30th October 2008, 12:52
