Results 1 to 10 of 24
Thread: Spanner light flashing this morning & LHM, then OK after 30 secs - ODD!!!
    Birmingham
    Default Spanner light flashing this morning & LHM, then OK after 30 secs - ODD!!!
    Had this happen this morning.
    Left home, all OK, got to the lights and noticed the spanner light blinking at me and no power over 3k rpm, 30 secs later it was fine again.
    Im going to do a Fault Code check later and will report back but please comment on possibilities. Just a glitch I wonder?
    Bye bye Vec B
    - Hello Siggy!
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Too many possibilities to guess , best just to get the codes read and see what comes up .
    and still loving it
    Birmingham
    Just checked it and NO FAULT codes stored. How weird is that??
    Bye bye Vec B
    - Hello Siggy!
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Might be just a blip mate had a few on my old vectra like that but no fault stored
    Irmscher Insignia CDTI 130
    Regular Member Munkey's Avatar
    Jun 2012
    United Kingdom
    possible its just a bit of moisture - had it on a 5 series. Errors coming up occasionally (but only after there was a spell of rain & then it was warm - water vapour etc).
    Birmingham
    Cool. Nowt to worry about then. Will carry my ode reader with me at all time just in case, LOL!
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    Happened again on way home from work yesterday, Car with spanner popped up whilst stationary in traffic, wouldnt rev over 3,5k rpm, 30 seconds later - all OK again.
    Checked for trouble code this morning and only one that came was P0700 - Ambient Air Temp senosor and Alarm Circuit. Would these bring up the light?
    Bye bye Vec B
    - Hello Siggy!
    It's quite unusual to get Safe Mode, which then clears very quickly
    Normally once applied it remains in place until the engine is switched off, restarted, or having to wait some time
    I had a similar problem where Safe Mode was being applied, but on switching off, waiting 5 minutes, and restarting all was well (typically once a month, but was eventually down to once a week)
    No fault code could be found
    This suddenly stopped, but was then replaced by the Emissions Warning Light once a fortnight
    The fault code was returned as the EGR Valve, so had the dealership order me
    I then replaced the Fuel Filter, and found that it looked like the previous one had not been replaced
    This issue has completely disappeared
    In general, my experience and recommendation is to wait until the fault becomes more common, as erratic codes tend to be difficult to diagnose and incorrect
    I suspect your issue is associated to the Air Temperature Sensor (engine)
    This suggests it is nearing the end of its life
    I would suggest replacing this first and then compare
    The Alarm should not be activiting Safe Mode during normal driving
    Birmingham
    Thanks mate, where is the Air Temperature Sensor (engine) located?
    Im very much into preventative maintenance, hence why im trying to catch IT before IT catches me. Im driving down to Southampton on Monday and maybe Isle of Wight, ill make sure I take my laptop with me!
    Could it be dodgy fuel? I have been using Cheapo Asda fuel recently. I have popped in some Redex this morning to try and clear up that too.
    Bye bye Vec B
    - Hello Siggy!
    Quote Originally Posted by Vaux-Man-G View Post
    I can't work out what type of car and engine you have, as your profile doesn't make it very clear
    I know where it is on the Y30DT, but not sure on the 2.0 DTI so I am quite sure someone can advise
    I would expect it to be on the nearside of the engine near to the inlet manifold
    Very unlikely as fuel and air are kept separate until after the air temperature sensor
    However, it wouldn't hurt to try 180 litres (three consecutive tanks) of a premium fuel
    Don't bother with any fuel additives (we sell them but I don't use them)
    As an aside, the air temperature sensors issue may be due to the MAF sensor nearing the end of its life
    Have you driven through water / flooding recently?
    If so, remove the cover to the Air Filter box and inspect it
  1. Flashing Spanner
    By Knight Rider in forum Engine & Drivetrain
    Last Post: 6th September 2012, 17:36
  2. flashing spanner and wont start
    By jofenan in forum Engine & Drivetrain
    Last Post: 3rd February 2011, 13:52
  3. flashing car and spanner light
    By signumturbo04 in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2010, 16:32
  4. The "flashing car picture with spanner through it" light
    By Big Dave in forum Engine & Drivetrain
    Last Post: 9th February 2008, 04:33
  5. flashing spanner light
    By carp in forum Engine & Drivetrain
    Last Post: 27th April 2006, 14:53
vauxhall vectra 2.0 dti 04 spanner light flashing
