When in the Passenger seat there is a decent amount of road noise from the corner of the passenger door where the wing mirror is any ideas?
Tyre noise?
Dodgy window seal?
Well just outside noise really I don't have the same issue for the drivers side.
9 times out of 10 its the tyres or poss bearing
have a look here
http://www.vectra-c.com/forum/showth...=poll+dronning
Its a wind noise like a seal issue
and its from the front not the back
Wingmirror not on tight? Or sound deadening missing from under the wingmirror cover?
Ahh how would I access to check, it sounds like when a window is open just slightly like a whistling noise
I think you can pop the trim off where the wingmirror is on the inside of the door? Don't try it though until someone confirms!
