Thread: O/S/F window adrift from regulator
    Feb 2011
    eastbourne
    Default O/S/F window adrift from regulator
    Hi guys
    My 57 vectra hatch osf window became detached from the regulator. I have lowered the window as normal and when it got to the bottom it went with a bit of a bang. The motor still sounds operational and I have manually closed the window by pulling up the glass by hand
    Three things
    1) is there a common fault people are aware of
    2) how is the glass attached to the regulator
    3) is the door card fairly easy to remove
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Had this with my driver's door window; the spot-welds fracture and the motor no longer works the lift/drop mechanism. I got my garage to sort it as it was beyond my expertise although the door-card came off fairly easily. I believe it is a common-ish problem.
    Feb 2011
    eastbourne
    That sounds very possible. How was it fixed?
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    new regulator is normally cure...
    Feb 2011
    eastbourne
    Don't like the sound of that. Guess there's only one way to be sure. If regulator is faulty is it the the sort of thing I could find as a pattern part
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    probably not, but wouldnt have thought they were that dear 2nd hand..
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    Try euro car parts, they stock loads of different window regulators and motors
  1. Window regulator is same or different ?
    By SandyGBR in forum Bodywork & Interior
    Last Post: 21st September 2011, 12:03
  2. Window Regulator
    By manimal in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2010, 14:32
  3. Window regulator?
    By dh.dti in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2009, 12:52
  4. OSF WIndow regulator
    By addyboy1982 in forum Parts for sale
    Last Post: 6th June 2009, 13:40
vectra b osf window regulator
