Results 1 to 10 of 26
Thread: Is it right to only have one rear fog light working ?
    Regular Member muffking's Avatar
    Default Is it right to only have one rear fog light working ?
    Me again.
    I have a good fog light bulb in my near side rear cluster, but only the off side one comes on. I originally thought it must be a supply problem, but every veccy I've seen since with rear foggys on has only had the o/s/r lit. Is this right ?
    yep, as supplied straight from the factory.. just one foglight wired in..
    That's weird.
    Well I suppose at least I've got a spare bulb as it's the same as the reverse lamp and probably the indicator too
    Regular Member Marc 100's Avatar
    Nov 2005
    Berks
    I'm amazed they'd bother to give you the bulb for free if they haven't wired the socket in...
    It used to be the other way around - you got a wired in socket (presumably for other markets that require two rear fogs) but either a blanking cap or no bulb. You therefore had to simply buy a bulb in order to get two rear fogs.
    Saw a Zafira with two rear fogs today...
    [Ex]Admin Duncan's Avatar
    This thread should help.
    Now I know it's not broke
    Well done Dunc.
    Regular Member Ross DTi 2.2's Avatar
    Münster, NRW, Germany
    I cross wired mine so that both foglights work. It wouldn't have passed its roadworthiness test in Germany without this being done.
    I've stated this before: Why on earth do Europe have an issue over dual rear fog lights. Their job is to make you visible in heavy fog. If somebody mistakes them for brake lights, they've already done their job. FFS.
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    i think that fog lights should be banned and have decent sized rear lights,most people dont know how and when foglights should be used,why the f**k do any one use them in a built up area? if you need fog lights in a built up area you are going too fast for the conditions ,dont see any parked cars with fog lights,or motorbikes or bicycles for that matter,i will only use my fogs if im out of town on an empty road,as soon as a car is behind me i will turn it off as i want them to see my brake lights come on
    Quote Originally Posted by solorider View Post
    That has to beg the question.... Why even turn them on in the first place if that's what you do?
    'cos you wanna know that some car speeding up behind you can see you before it's to late
  1. Boot light and rear de-mist not working
    By Sixer in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2013, 14:48
  2. rear fog light not working
    By keggy77 in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2012, 16:59
  3. I now have a working rear interior light
    By rob warrington in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2012, 16:55
  4. rear midle break light not working?
    By sr150i in forum Bodywork & Interior
    Last Post: 1st February 2011, 20:06
  5. help n/s rear fog and reverse light not working
    By howardc03 in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2009, 21:07
