Results 1 to 10 of 11
Thread: Towbar wiring - dedicated or just splice in?
    Sep 2011
    lewes
    Engine : 1?? - Teapot mapped
    Mileage : 125000
    Default Towbar wiring - dedicated or just splice in?
    What are your recommendations chaps for towbar wiring for hatch, dedicated or chop in to the current wires?
    Obviously dedicated is neater and no doubt quicker but are there any other advantages?
    I'm aware its quite a few £ for a kit
    Also does it need anything activated via tech2 to work?
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    am not sure but i know it does need tech2 if you do it the proper way
    Dec 2011
    Seaham
    I beleive you will need proper modules otherwise the canbus system will go crazy! Mine has some fancy relay/module installed and I do not get bulb warnings up, altthough it is a bit quirky, when you cancel the indicators, it will flah the other side briefy after about 6 seconds?
    Aug 2010
    Leeds
    Just bought one off e bay it comes with a module and plug in harness, not fitted yet but will need extra wiring for caravan wiring.
    My Astra had the dedicated wiring kit it plugged in.
    Must be better idea, but i had to have the system switched on hope the vectra is not the same.!!
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Quote Originally Posted by dan danz View Post
    No it doesn't always need tech 2 - I got the proper Vx loom and it just worked straight away. If you splice into the existing wires it may well mess up the bulb failure warning system - you can get relays to prevent that. If you want the safe option, or think you might want to take it all off again anytime the correct loom is easiest.
    Nov 2010
    doncaster
    i have got a 2007 vectra and had a detschable towbar fitted with the wiring harness that plugs in the fuse box in boot and all works correctly and no tech 2 needed
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Spliced mine into existing wiring very tidy finish. To avoid canbus fault use indicators as normal, Tail lights spliced into number plate lamp and brake lights into 3rd tailgate brake lamp (cost 1 hour of my time locating cables and scotchclipping)
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    get the proper plug in loom and module it is by far the best option, the 2 i have fitted worked straight on the car and tech 2 is only needed to activate trailer check control (bulb failure for the trailer) and the legally required lamp light on the dash when you have a trailer connected and indicate (the law requires either a dash light or buzzer, much prefer the light )
    Sep 2011
    lewes
    Mileage : 125000
    Okay, so it seems the dedicated wiring is the way to go.
    Is this one ok for a 54-plate hatch with full canbus?
    http://www.ebay.co.uk/itm/2307752170...84.m1423.l2649
    Sep 2011
    lewes
    Mileage : 125000
    Update - the one I got of eBay had a GM module and dedicated wiring with it, result!
  1. Towbar wiring - gm dedicated harness
    By Richie_rich in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2012, 18:28
  2. Dedicated towbar wiring
    By cus2000 in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2012, 12:48
  3. Towbar wiring
    By Andyc6845 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2011, 17:59
  4. towbar wiring
    By Al 22 dti in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2011, 07:46
  5. tap splice into CD70 wiring/connector
    By Caveman_nige in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2010, 21:47
vectra c towbar wiring diagram
splicing towbar wiring
splicing in a tow bar
vectra towbar wiring diagram
vectra c towbar wiring requirements
vauxhall vectra trailer wiring
vectra c towbar dedicated wiring kit
vauxhall vectra towbar electrics
fitting a vectra c towbar will it mess with the bulb warning light
vectra c towbar electrics
vauxhall vectra c 2008 deicatied wiring kit
How do you wire up a. Towbar on a vectra c
vectra c hatchback towbar electrics
vectra c towbar wiring kot
