Results 1 to 10 of 15
Thread: Z28NET Coilpacks?
    Mar 2012
    Hampshire
    Default Z28NET Coilpacks?
    Hi there,
    I was misfiring on cylinder 5 last week, so took the oppertunity to have my set of NGK Iridium plugs gapped to .8 and put in. The car drives fine again but I can't help but notice a slight "bump" when idle, I dont even know whether its just me, but I don't think the idle is as smooth as it was.
    So im thinking maybe a coilpack is on the way out. I do have the club trade card but wondered wheres the best place to get coilpacks for the z28 block as vauxhall will probably be expensive.
    Tom
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    same engine as the saab mate so Neo Brothers will be a good bet..
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    A PM from spoons that is doing the rounds
    Make sure you speak to this guy. Identical coil pack is about £37+VAT from these guys. £10 postage.
    You can get the coilpacks cheaply from:-
    Rob Hicks
    CES UK
    01978 365 392
    He also does the NGK R7438-8 racing spark plugs as well
    Yes there are 6 coilpacks, one for each cyclinder and no you dont have to replace all of them.
    Try to identify which one is faulty and just replace that one. IF you get really stuck, buy three new ones and replace the back three (as they are hardest to get to)... then use the remaining coilpacks to find the faulty ones at the front... trial and error. But the front are much easier to get to
    Be ware that when I ordered mine they send 1 wrong one which I didnt realise until the engine was stripped
    Mar 2012
    Hampshire
    Thanks!
    I will give him a call and order a couple of coilpacks. Also... those NGK racing sparks, any benefit to me replacing my iridiums with them that I have just put in?
    Quote Originally Posted by Ziggy View Post
    Rob Hicks
    CES UK
    01978 365 392
    Full Member gibbon7000's Avatar
    lincs
    I got 3 from CES UK £140 inc VAT and Postage. Very helpful guy. Make sure you speak to Rob, I originally spoke to another guy from the sam enlace and he was gonna charge me £80 +VAT.
    Vauxhall charge something like £249 each and I'm not even sure if that is VAT inclusive
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    spoons
    Guest
    Quote Originally Posted by the_rocker View Post
    Thanks!
    Not really unless you are running very high boost (20+psi) or Nitrous Oxide
    Your Iridiums should be good enough. The racing plugs run at cooler temperatures which is important on high power mapped engines and are pregapped at 0.7mm instead of the recommended 0.8mm
    I only use them because of my Nitrous install
    Mar 2012
    Hampshire
    Quote Originally Posted by spoons View Post
    Im never to going to go that far with the vec, in fact after a year im probably going to lay my hands on a 2006 BMW M5. But I would love to see how the vec goes with NOS, got any videos?
    spoons
    Guest
    Yep Lots... Here using NOS against Stage 1 - Stage 2 Remapped Vectra VXRs with 300-330 BHP
    http://www.youtube.com/watch?v=cloMlipVXNg
    http://www.youtube.com/watch?v=nrsgCx1YBhM
    http://www.youtube.com/watch?v=jmPHxK9plCk
    Mar 2012
    Hampshire
    Nice! Now get a video up of the speedo going upppppppp!!
    Mar 2012
    Hampshire
    Well,
    Had my NGK Iridium Tip plugs put in and gapped to .8. My mechanic also switched coilpacks 5 and 6 around for me so that if it was a faulty coilpack, the misfire would happen on cylinder 6 now instead of 5.
    Anyway.... I drove the car away, seemed fine, but i couldnt help but think something felt different about the car. It was pretty hesitant on the throttle and it seemed to be down on power. Anyhow, after cleaning it today I had a sit in it for a while and I can still feel a slight bump on idle, so I took it out for a spin and sure enough, when them revs go up, i can feel and hear that misfire. Gave it the beans as well and got the engine light up again.
    Needless to say, since the plug change and coilpack switch over its a lot less noticable.... But I think this has to be a dodgy coilpack. You guys agree?
  1. Z28NET tapping under load.
    By Hyperhart in forum Engine & Drivetrain
    Last Post: 28th November 2012, 16:04
  2. Coilpacks on 2.2 Facelift / PreFace
    By spennny in forum Engine & Drivetrain
    Last Post: 13th September 2012, 10:33
  3. what turbo fits z28net??
    By jeppehjortlund in forum Engine & Drivetrain
    Last Post: 2nd September 2012, 18:27
  4. Z28NET Head Gasket
    By the_rocker in forum Engine & Drivetrain
    Last Post: 30th July 2012, 17:14
  5. Z28net- Couple questions
    By lee866 in forum Engine & Drivetrain
    Last Post: 15th June 2010, 09:32
z28net vectra c stage 2 quel modification
