Results 1 to 10 of 11
Thread: Limp Home mode
    Nov 2010
    Coventry
    confused Limp Home mode
    Hi all (again)
    I have an 04 Signum 2.2 Diesel Auto with 80k on the clock and a new turbo last October.
    Over the last few days my car has gone in to limp home mode when I put my foot down to overtake or going uphill.
    I have also noticed grey smoke in my rear view mirror.
    When I accelerate I also notice a sound similar to that of the airvents blowing fast.
    I had a brief check for split pipes/hoses but could not find anything.
    Any advice appreciated
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    By the sound of it gary you are pretty close to the problem by describeing the blowing sound , get a mate or the missus to rev the engine while you look around under the bonnet .
    likely suspects are the intercooler pipes that run from the turbo down through the intercooler and back to the manifold remember there are two right at the bottom shaped like u bends .
    and still loving it
    Regular Member mikey c's Avatar
    Plymouth
    or get someone to rev it while you spray it with wd40. makes those tiny splits show up alot easier!
    Nov 2010
    Coventry
    Tried looking again with a friend on the pedal and me under the bonnet with some wd40 - but no luck.
    I sounds like the noise is coming from the off-side side of the engine, low down. When I rev the engine hard black smoke comes out.
    Are there any pics of the inter cooler pipes on the 2.2 diesel?
    Engine : 2.0DTi
    Mileage : 73350
    DTI engine layout 2.jpgengine pic for you ,The two large pipes are your intercooler pipes .
    for access to the lower pipes its best to remove the front bumper .
    and still loving it
    Nov 2010
    Coventry
    Thanks for the pic - the top of these pipes are ok, so I will check the forums for help on removing the bumper
    Watch this space
    Nov 2010
    Coventry
    Hi just another question -if the intercooler pipes are damaged can I ust take them off to repair or replace? Or will it be a case of draining off anything or degassing the AC?
    Thanks again
    Engine : 2.0DTi
    Mileage : 73350
    The intercooler pipes are essentially dry , they carry the exhaust gases from the turbo back to the manifold , the most you will find is some residual oil and some carbon based gunge
    and still loving it
    Nov 2010
    Coventry
    Ok - I have now checked all pipes but nothing found. Took it to a local garage this morning after the mil light came on last night. MAF sensor is their diagnosis. So I am now £156 lighter and will fit it this afternoon.
    Watch this space.
    Nov 2010
    Coventry
    OK - MAF fitted but the problem still remains - is this because I am still waiting to clear the fault codes?
  1. limp home mode
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 22nd September 2012, 09:12
  2. Limp Home mode
    By Bredsticz in forum Engine & Drivetrain
    Last Post: 12th July 2012, 19:43
  3. limp home mode
    By fig in forum Engine & Drivetrain
    Last Post: 20th January 2010, 23:18
  4. CR2 going into limp home mode
    By plasma in forum Diesel Engine related
    Last Post: 17th April 2006, 20:45
