Thread: Radiator removal and capping off
    Nov 2010
    Maidstone
    Default Radiator removal and capping off
    I have been asked to remove a radiator from the wall and cap off completely but no idea where to start, its an almost new build but need some advice on how to. Can i just undo both connections and cap each open legs or will i need to connect a pipe to complete the loop again? Any help appreciated.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    You can just cap off either end as one end is the flow loop and the other is the return loop. I fitted a radiator to my down stairs toilet lately and by luck the manifold was under the toilet floor and it had quite a few capped off ends. Remember to drain down the system before you remove the valves though, or you will have water everywhere.
    HTH.
    Nov 2010
    Maidstone
    How do i drain down the system?
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    ours has a drain tap on the pipework down stairs just connect a hose to it and drain it out the back door open the bleed valves on the rads so it drains quicker,thats how i've always done it any way
  1. Intercooler radiator removal without water radiator
    By Whosane in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2012, 15:48
  2. new radiator
    By rfc52 in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2012, 11:33
  3. 2.2 petrol radiator removal
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2012, 22:33
  4. Radiator on 3.2 GSI
    By JJGSI32 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th February 2011, 22:18
  5. Air con radiator
    By VECTRA HEAD in forum Engine & Drivetrain
    Last Post: 24th March 2010, 13:38
