Results 1 to 2 of 2
Thread: Z20NET help appreciated!
    Regular Member mikey c's Avatar
    Plymouth
    Default Z20NET help appreciated!
    Hi everyone,
    I have a 54 plate 2.0t with Z20NET engine, done 75k miles.
    I bought it back from my mate with an ECU issue and was cutting out totally every few minutes and wouldnt restart for 5 mins or so.
    ECU has been replaced and now runs fine except the engine management light comes on after a short trip, loss of power and is cured briefly by turning engine off / on.
    Tech 2 is bringing up P0325 which is knock sensor circuit.
    As said ECU is replaced.
    Knock sensor has been changed.
    has had a full service.
    But it still continues.
    Anyone got any ideas what else we can check?
    South east
    There are two boost control valves that often fail, you could try changing those, as they only cost about a tenner each and can be DIY fitted. One is to the left of the turbo, one is to the left of the throttle body. I think they're both mentioned in Jezzy's Z20NET spec sheet thread.
  1. your help would be most appreciated
    By bigbow in forum Bodywork & Interior
    Last Post: 14th November 2012, 23:41
  2. any help appreciated....................
    By coopey in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 18:10
  3. Help appreciated
    By mickyg in forum Vectra C / Signum Troubleshooting
    Last Post: 14th May 2010, 15:51
  4. 3.2 V6 Fault - Help Appreciated
    By pjjohnst in forum Engine & Drivetrain
    Last Post: 9th May 2009, 16:43
