Thread: Front brake pad problem, constant rattle until brake pedal is depressed
    Sep 2011
    West Yorkshire
    Default Front brake pad problem, constant rattle until brake pedal is depressed
    Hi, since replacing my front brake pads on my vectra the left hand side pad to the rear of the caliper is rattling around endlessly especially at speed, which is annoyingly audible in the drivers seat. The pads were relatively cheap at £15 but you still dont expect this nonsense. The rear pad fits into the piston with a retaining spring and is loose to the touch.
    Any ideas Or similar resolved experiences would be appreciated greatly!
    PS, could it be possible that the retaining spring clip on the front of the caliper isnt tight enough?? I put as much tension on it as I could before refitting, does the spring affect the rear pad??? Thank you.
    Motherwell Scotland
    I had a similar problem only at the back. Turned out to be a warped disc, it tapped quite bad but went away with speed or when I braked, when I stripped the brake pads off one side was more worn than the other. Fitted new discs and solved the problem. Might be the same problem.
    Sep 2011
    West Yorkshire
    I cant see this being the case, as new discs were fitted at the same time as the pads
    Thanks anyway though!
    Full Member stuart bigboy's Avatar
    May 2007
    kent
    i have this same problem since i changed pads and discs last week did you ever find out what it was
    Full Member OLD DOG NEW TRICKS's Avatar
    Jun 2014
    Rochdale , gtr Manchester
    6 Post(s)
    Vehicle : vectra c
    Trim : GSI
    Mileage : 93K
    One clip snaps into the piston and the other should push really tightly throught the caliper , then the rattle spring holds the pads tight in place .
    If they are loose and they should not be they could be the incorrect pads .
    this is the pad clip pushed through and it's a very tight fit.
    May 2007
    kent
    all seems to be ok with the spring just seem to be really loose in the holder
    Oct 2012
    Llangollen North Wales UK
    Trim : Elegance
    Engine : 1.9cdti 120
    Mileage : 118 000
    Ive fitted cheap pads front and rear and got rattles and noises, changed them for genuine Vauxhall one and quiet as a nun,
    Sep 2010
    Quote Originally Posted by Whiteknight841 View Post
    I've just been through 5 sets of discs in one year, even three sets of 314 VX ones due to warping within a week. I'm sure I read on here that some cheap pads do rattle in the housing. Get VX pads or Mintex/Mtec ones.
  1. For Sale: Vauxhall Insignia Brake Pedal Alloy Cover - SRI sports pedal cover
    Last Post: 20th December 2012, 21:36
  2. brake pedal problem
    By Swedge in forum Suspension, Wheels & Brakes
    Last Post: 1st September 2012, 17:44
  3. Brake pedal ?
    By Denbo in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 01:47
  4. brake pedal
    By barrie m in forum Suspension, Wheels & Brakes
    Last Post: 12th February 2010, 21:21
  5. 02 Vectra C 2.2 Dti- Brake Pedal Problem
    By Devildriver in forum Suspension, Wheels & Brakes
    Last Post: 3rd April 2009, 15:29
https:www.vectra-c.comforumshowthread.php168381-Front-brake-pad-problem-constant-rattle-until-brake-pedal-is-depressed
brakes rattle until you push brake pedal
brakes rattle when depressing brake pedal
vectra c brake pad rattle
vauxhall insignia sri loose brake pads
opel astra brake pads is rattling
