Thread: Intermitant ecu light on
    Jun 2011
    wolverhampton
    Default Intermitant ecu light on
    Hi guys a friend has just popped round with his 53 plate 1.8 with engine light on intermittently. Read the codes and it's showing p0170-11 fuel trim system rich, current fault. It also had stored fault code p0100-06 mass or volume air circuit low input but this code cleared and wouldn't re occur. Any ideas where to start guys
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Potential causes include a vacuum leak, unmetered air leaks, bad O2 sensor, oil contamination in MAF connector or O2 sensor connectors, defective MAF (Mass Air Flow) sensor
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Previous P0100 refers to MAF so maybe a place to start followed by the O2 sensor on the top of the manifold
    Jun 2011
    wolverhampton
    I was thinking with the combo of both codes that it could be the air mass sensor as it was also only showing 5kg at idle which seams a little low to me. Was expecting more like 8-9kg to be honest?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I have had two 1.8xe engined cars.
    One threw up codes like your one intermittently for the MAF and it turned out to be the flexi pipe on the exhaust was split
    The second one needed a new MAF and O2 sensor as when the MAF goes it overfuels and burns out the O2 sensor. Also only get a genuine MAF as the ebay ones are poo
    Jun 2011
    wolverhampton
    Does it have an up and down stream O2 sensor? If so I'm guessing you mean replace the upstream sensor?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by sriandy View Post
    not sure which one it is but it sits on top of the manifold at the front. I would check the flexi pipe first tho
    Jun 2011
    wolverhampton
    If it's on the manifold that will be up stream of the cat then cheers. I will be checking it over better at the weekend hopefully in the dry as was to wet tonight to have a mooch, just a flying visit tonight
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Need to see live data.
    See what front an rear oxy sensors are saying/ doing
    Veiw long an short term fuel trims.
    If you have a multimeter you can confirm voltage at mad an ixy to see if their the same as what ecu thinks they are
    Jun 2011
    wolverhampton
    I couldn't see any live data for the fuel trims mate. The oxy sensors seamed all ok and switching as they should.
  1. intermitant wiper
    By Kaikianjames in forum Electrical & ICE (including SatNav)
    Last Post: 4th January 2013, 21:25
  2. Intermitant EML light driving me bonkers!!!
    By Mc naughty in forum Engine & Drivetrain
    Last Post: 27th February 2012, 18:24
  3. Indicator intermitant fault
    By Photog Dave in forum Electrical & ICE (including SatNav)
    Last Post: 31st March 2011, 22:51
  4. intermitant rev and speedo
    By vectra-sri-jon in forum Vectra C / Signum Troubleshooting
    Last Post: 21st February 2008, 16:00
