Results 1 to 10 of 13
Thread: Sump plug removal
    Regular Member Fitzy-2.0T's Avatar
    Hertfordshire
    Default Sump plug removal
    So I brought a sump plug and a new socket and this thing is stiff as they come I cant get enough purchase from the front of the car and its doing my nut in. Some numpty has air gunned it on probably. I need a ramp
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Bar on the socket pipe on the bar loads of purchase
    Hertfordshire
    I'm going to source a breaker bar and do it that way.
    Jun 2011
    wolverhampton
    That much force on a t47 is not gona end well!
    Jun 2011
    Vehicle : vectra
    Year : .....
    With him mentioning a socket presumed it was a hex head,your right though wouldn't recommend this method with a torx
    Jun 2011
    wolverhampton
    Quote Originally Posted by patch22 View Post
    Don't think many Vauxhall Sumps are
    Normal nuts anymore most are t47. And you can bet it will be a t45 in use as 47 are hard to get hold of. Mine was a snap on costing about 15 quid for 1 socket
    Hertfordshire
    What force with a torx? its the only way to undo it? I have a new sump plus so I just need it out.
    11 Post(s)
    Quote Originally Posted by sriandy View Post
    T47?
    Is that a typo? If not a hex bolt, then it will be a T45
    Jun 2011
    wolverhampton
    Not a typo its actually a t47 not 45 as snap on advertise it for use with Vauxhall sump plugs. Try your 45 next time and you will see it's a little loose in there.
    Regular Member sheepish's Avatar
    Yorkshire
    If it's in there for good, there are other ways of getting the oil out, see:
    http://www.vectra-c.com/forum/showth...ump-experience
    I haven't got one, but there use seems to be quite common...
  1. sump plug removal
    By mon in forum Engine & Drivetrain
    Last Post: 13th January 2013, 21:03
  2. Sump plug
    By shb1988 in forum Engine & Drivetrain
    Last Post: 23rd August 2012, 18:37
  3. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  4. sump plug
    By luke.oldham in forum Engine & Drivetrain
    Last Post: 7th January 2011, 22:33
  5. Sump Plug ?
    By gsxrster in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2008, 14:59
vectra c using hex sump plug www.vectra-c.com
T47 torque sump plug
