Results 1 to 10 of 25
Thread: Engine lumpy now Engine Management Light is on
    Full Member Fitzy-2.0T's Avatar
    Hertfordshire
    Default Engine lumpy now Engine Management Light is on
    Hello,
    I had a previous thread in relation to the engine feeling lumpy well today it seems worse and now the engine management light has come on.
    1. Is there anyway to read the code without expensive garage equipment.
    2. Has anyone else experienced this before, outcomes resolutions
    The Car is a 1.8 Peterol 52 Plate
    Regular Member John Bishop's Avatar
    Oct 2010
    There is a way that the codes can be read. Search pedal test on the site
    Hertfordshire
    I've tried to do the pedal test break and accelerator pressed down position and key turned to position 2 nothing happens?
    Oct 2010
    Hopefully someone local might pop up and offer to read the codes
    Regular Member bigdave1701's Avatar
    York
    Pedal test only works on specific engines/years. you can get a code reader for about £20 on eBay then ask on here if someone can tell you what the codes mean.
    Hertfordshire
    Well I've managed to do the Pedal test.
    First 2 codes
    0170
    0302
    Oct 2010
    0170 Fuel trim malfunction
    Oct 2010
    0302 Cylinder 2 misfire
    Hertfordshire
    Cheers John, what would be the cause and fix for this? Sounds expensive :-s
    Oct 2010
    Honestly don't know. You got an andriod or iphone as there is a free code reader you can get. Presume the misfire could be a glow plug or wiring
  1. Engine Management Light
    By R1cky in forum Troubleshooting
    Last Post: 17th March 2012, 20:24
  2. Engine management light
    By woods in forum Engine & Drivetrain
    Last Post: 29th November 2010, 22:08
  3. Replies: 13
    Last Post: 20th May 2010, 20:09
  4. HELP!!! Engine Management Light has come on
    By mathewjcooper in forum Engine & Drivetrain
    Last Post: 22nd July 2009, 22:21
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
vectra lumpy engine management light on
