Thread: Footwel lights.l
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Default Footwel lights.l
    Need to do this mod,think it looks great,i have all the bits and am ready to go,popped out the alarm censor,removed light cover,removed 3 torx screws then after a bit of a struggle managed to remove the whole assembly along with the glasses holder from the roof and unplugged,this is where i get stuck was going to fix wires to the bulb holders as in the how 2 i read as my soldering skills are not good, so i need the circuit board off the holder, can free the front and sides but the button end is not having it,its the 4 button type with the map lights,gave up for now as i was afraid of snapping the board, any advice would be really appreciated
    Jul 2011
    UK
    Year : 06
    Really simple mate what I did was take a bulb holder out take the bulb out put a wire down each side then put the bulb in job done mine been like that for nearly a year now I've also done this with my footwells
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Just use small bit o solder make sure tin the wires aswel.
    you could always just wrap cable round bulb connector for now. An then get someone local to our dab of solder on for you
    Jun 2011
    Vehicle : vectra
    Year : .....
    Saw that when you originally put it up marc looks sweet mate really neat job, you say take a bulb holder out how do they come out?
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by patch22
    Cheers mate they twist out u need to take the roof light down and twist the holders and will come off
    Jun 2011
    Vehicle : vectra
    Year : .....
    Quote Originally Posted by Critch View Post
    Sorry critch me being a bit thick probably,but don't quite understand how i would wrap the wires round the bulb connector
    Jun 2011
    Vehicle : vectra
    Year : .....
    Quote Originally Posted by marc vectra sri View Post
    thanks for that info marc will try it that way next time i have a go at it
    wirral
    36 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Strip the end say about half an inch then literally just wrap it round brass connectors
    Jun 2011
    Vehicle : vectra
    Year : .....
    thanks both of you for your input,hopefully get it sorted next time with the help of your info
  1. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  2. Replies: 2
    Last Post: 31st March 2010, 13:30
  3. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  4. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
