Thread: Signum auto gear failure
    Regular Member Alzay's Avatar
    May 2012
    Perth
    Default Signum auto gear failure
    I was just driving along when I lost all gears it's a 2.2direct anyone know what it could be I,ve 67k on the clock I'm dreading it being the clutch but I've had no slipping.
    Engine : 1.9 CDTi
    Auto's dont have clutches but the auto box does suffer with coolant getting into the auto box oil.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    as lee says not clutch and there is a problem with the seals bracking aways causing water contamination with in the gears box means a new box or a rebuild and they aint cheap hence i bought warranty for my car but it could be somet as simple as a speed input sensor or somet on that line
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    As your car is 2004 it may not have the issue of oil getting into the gearbox as I believe this was fixed around 2004. Depends on how early your car is.
    May 2012
    Perth
    Cheers guys I'll get it looked at but if it's around a grand to fix I think I'll scrap it.
    May 2012
    Perth
    I got a quote of £3200 to recon my box, so my Siggy is going to die, not paying that for it it's not worth it. Damn shame nice car too.
    Dec 2011
    Seaham
    Can you get a second hand box fitted?
    Engine : 1.9 CDTi
    Where are you based?
    Maybe sell it as spares or repairs?
    Jun 2011
    Northumberland
    Vehicle : Vectra 1.9 cdti 16v (150)
    Trim : elite
    Alzay
    I am in the process of resurrecting my Vectra 1.9cdt1 with the six speed Aisin Warner AF40 Box.
    My thread is here
    Autobox Knowledge AF40?
    Pure economics often come down on the side of scrapping or getting what you can for the car spares or repair. Inevitably the price of the job is going to be high. The hours required to "drop" the box and bolt on another one alone mount up before the skill and expertese required for rebuilding.
    Do you have any more information on your fault, and what specific autobox you have? It seems that you have gone from having a box with 67K on it which works fine, to a catestrophic failure where you have no gears at all in an instant. Do you still have no gears?
    Regards Neil
  1. Signum ECU failure!
    By GrahamS in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2011, 16:12
  2. auto gear box help anyone?
    By lukesignum in forum Engine & Drivetrain
    Last Post: 25th September 2010, 00:30
  3. Auto gear changes
    By Alansilverfox in forum Engine & Drivetrain
    Last Post: 13th June 2009, 19:56
  4. Auto gear box only 2nd & 5th pls help!!!
    By watkins1172 in forum Engine & Drivetrain
    Last Post: 12th January 2009, 19:48
