Thread: Any Sparkies here?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Default Any Sparkies here?
    Well as some of you will of seen some lovely person smashed my windscreen last night so in attempt to prevent it from happening again.
    I want to wire in a security light.
    looking to see how complicated it would be?
    i am a qualified vehicle technician working with vehicle wiring an electrics daily. So I have an understanding of electrics. But my extent to house electrics is fitting new lights. To the connectors that are already in place.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    am a sparky matey
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    easyest way mate is wire it up with flex and a plug to put a 5amp fuese in the plug thats the simple cheapest way if you want the hardest way let me know lol
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    That sounds like a plan cheers mate
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    no bother fella
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Not the sort of thing i'd recommend, but If you do use a plugtop & flex (normally used as a temporary solution) then you might want to make sure its at least RCD or RCBO protected and clipped..
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    What does that mean? I take rcd are the circuit protectors that trip?
    Take it it wwould be a fairly simple job for someone in the know to fit it properly?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Whys that Pete his socket is fuesed down its like pluging a lamp in really isn't it apart from out side plus his house is already protected with rcds or rcbos meaning a standard 30ms trip carnt see the problem
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    Quote Originally Posted by paulvectrac View Post
    Not every property in the UK has RCD's or RCBO's fitted though, and some still have perfectly legal BS:3036 rewireable fuses, also need to consider that some old power/lighting circuits may not even have a cpc, So you're assuming that the Socket is RCD/RCBO protected and safe when that may not be the case. then theres basic protection from things like abrasions, and impact which need to be considered when getting a cable out of the house and into accessories such as a light fitting..
    Seen to many "temp" installs that have ended up being the root of problems..
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    i actually agree pete thats a good point lol critch i hope you have rcds lmao
  1. Any sparkies on here? Help needed!
    By stuball in forum General Chat
    Last Post: 6th December 2010, 22:37
  2. Tooth Belt Change and sparkies!!
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2007, 06:13
  3. Question for the sparkies on Veccy_C
    By blr123 in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2007, 19:50
