Results 1 to 10 of 16
Thread: tapping noise on startup when cold
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    Default tapping noise on startup when cold
    just a quicky my 1.9cdti 150 do they have hydrolic tappets as mine has just started with a little bit of a tap in a morning when cold only for about 2 seconds but it does remind me of my old astra when the tappet was emptying itself
    any info would help cheers
    Mileage : 000
    That sounds like it to me, most cars now a days have hydrolic tappets, they seem to do it more when the weather is colder, as long as the noise goes away after a few seconds it should be ok. my neighbour has a BMW and that "rattles" from cold.
    Nicking Ya Dinner.
    Yeah, mine too Bevis, I think it's the cold doing it, are you using 5/30 or 10/40?
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    yeah I've noticed mine sounding like a big 'ol tractor in the morning too. ... I set off immediately after I started the engine last week and wow was it loud ... quite worried I pulled in again and switched off then on again, paused a second or two this time before setting off and it was ok!
    now it's colder the oil is harder so suck up and pump round...so noisy top ends are more common..colder mornings also make the noise more apparent... my GSi taps like a swine for about 5 seconds...so i'm going to get some slick50 for mine.... cut down the wear in the oilless moments.
    sounds like a good idea with the slick50 might save a bit of trouble later down the line
    Mileage : 000
    Slick 50, I have used this before in previous motors, But I thought VX do not recomend putting in additives, as it might affect the propoties of the oil?.
    Nicking Ya Dinner.
    Mark, I gotta another niggle, I'm getting a small misfire on throttle rundown at certain lowish speeds, any ideas what might be causing it mate?
    2.0 dti
    Almost like a surge, as if the throttles not keeping up with my foot, and only for a moment.
    Cheers.
    Regular Member simac's Avatar
    Wirral
    In other cars i've owned i've used Magnatec oil as it is supposed to help reduce wear in this type of situation. I haven't put it in the vec yet.
    Regular Member POAH's Avatar
    Glasgow
    you want to make it worse
    slick 50 is not safe and you have no need for oil additives
  1. Scraping noise on cold startup.
    By erni3wi5e in forum Engine & Drivetrain
    Last Post: 18th March 2012, 14:20
  2. Cold Startup Problem
    By vwsaxon in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2011, 21:51
  3. White smoke on cold startup
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2011, 12:16
  4. Vectra c 2.2 tapping noise when cold help !!
    By stevemaz in forum Introduce yourself.
    Last Post: 26th May 2010, 13:17
  5. Z20NET Tapping noise when cold
    By Hyperhart in forum Engine & Drivetrain
    Last Post: 2nd February 2010, 00:17
vectra c 1.9 cold startup tapping noise
