Thread: Changing brake discs?
    Greece
    Default Changing brake discs?
    I have a my 2005 GTS 1.8, and wanted to upgrade to larger diameter discs, do i need to change calipers also? The current discs are 285 fr and 278 rear. I want to go 302 fr. the rim is the standard 17".Thanks for your help
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Yes you will need bigger calipers an carriers
    314mm from the 3.0 will be a nice upgrade
    Greece
    Thank you for the info! Will the 314's fit in a 17" rim; also, know of any reputable used parts store?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Yes they fit fine my v6 cdti has standard 17 sri. Wheels
    No a think best bet is eBay
    Greece
    Ok, will do.
    thanks!
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    guess postage is going to cost a huge amount but i have a mate who has my old 302 callipers, carriers and disk n pad set with 1k miles on them and not used them, i can see if he want to sell if you like ???
    emec#1
  1. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  2. Changing Rear Discs
    By scottymf in forum Suspension, Wheels & Brakes
    Last Post: 30th May 2008, 21:35
  3. Changing Front Brake Discs
    By rozzer1976 in forum Suspension, Wheels & Brakes
    Last Post: 17th August 2007, 22:09
