Results 1 to 10 of 19
Thread: Blanking EGR valve
    Jun 2012
    London
    Vehicle : Vectra 1.9 cdti (150)
    Mileage : 105,000
    Default Blanking EGR valve
    What is this?? By blanking it or putting a plate on it does that not effect the egr valve function? Can anyone do this because i think my egr is playing up!
    regards
    Mo
    Jan 2012
    Gloucestershire
    The EGR controls flow of exhaust gas back into the inlet manifold so it can have a second chance at being burnt and hence reducing NOx emissions. So, all the valve does is turn on and off to either allow exhaust gas out of the exhaust as normal, or recirculate for re-burn.
    Blanking this valve, which simply means putting a blockage in the recirculation pipe, prevents the exhaust gas from being returned to the inlet manifold so basically renders the EGR useless. Doing this causes the ECU to throw up an engine management light, followed by an emissions light, but doesn't actually cause any problems. In fact many would suggest it significantly improves performance at low revs and prevents the inlet manifold from clogging up with sludge.
    Anyway, what makes you think your EGR is playing up? They are fairly simple to clean out if necessary - no need to go buying a new one. There are How2s on this site to explain. If you post your symptoms, there will be plenty who can advise.
    Jun 2012
    London
    Mileage : 105,000
    Quote Originally Posted by DieselWig View Post
    Thanks for this. Makes sense.
    Well my engine management light is on (amber colour). The car does not seem to pull at all..no injection at all it seems.....but drives ok. People have been saying its the EGR valve. I have done a little reading on this forum and that seems to be the most common sympton. Will have a look at the HOW 2 section and see if i can find it. May have a go but scared I wont be able to do it.
    Lets see
    Regular Member John Bishop's Avatar
    Oct 2010
    Have read on the site that the 3.0 v6 cannot be cleaned and has to be replaced
    Jun 2012
    London
    Mileage : 105,000
    Quote Originally Posted by John Bishop View Post
    Really? It cannot be cleaned?? My garage guy said he would be able to do it...?!? HHmmmm...
    Anyone else able to conirm this...aprt from getting a new can I not do anything else?
    Oct 2010
    PM m8internet. Remember him mentioning it in a post. Bit of a ****** as I have a 3.0 v6 too
    Jun 2012
    London
    Mileage : 105,000
    I cannot find this?? Anyone can locate?
    Jun 2012
    London
    Mileage : 105,000
    So the only way to sort an egr valve issue on a 3.0 v6 is to buy a new one?? they cost ****** £500+ !!!!!
    Oct 2010
    From what I read they can only be replaced. Hoping I am wrong though in case mine goes t**s up!
    Oct 2010
    Tried to PM him but his box is full
  1. blanking egr valve
    By Garfo in forum Engine & Drivetrain
    Last Post: 12th May 2011, 14:43
  2. Blanking Egr Valve
    By Simo87 in forum Diesel Engine related
    Last Post: 31st May 2010, 17:22
  3. Blanking EGR Valve
    By Nav-Man in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2010, 19:31
  4. Blanking off EGR Valve
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2010, 19:12
  5. 120 8v EGR Valve blanking....
    By smiley-sri in forum Diesel Engine related
    Last Post: 14th August 2009, 23:08
