Thread: steering wheel removal.
    hull
    Default steering wheel removal.
    hi all, hoping to change my steering wheel soon from the nasty plastic one (57 reg cdti).
    Can someone tell me what size torx it is to undo?
    Also will i lose the radio/screen when i disconnect the battery for upto 1hr to deactivate the airbag. My stereo screen is a cd30 with the sri 3 line screeen which i fitted and didn't require a code. Are these cd30's coded?
    Thanks.
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    radio should reset itself,no code req the torx is a 50 iirc make sure you align the marks on the wheel and column or you will have a steeringwheel
    5mm off centre like mine
    hull
    Quote Originally Posted by mrk View Post
    Thanks mate, i didn't think the radio needed a code as it didn't when i fitted it, although the one i took out cd30+tid came with a code on the car pass. strange.
    hull
    Anyone else with any info on the cd30 needing a code???
    Regular Member gibbon7000's Avatar
    lincs
    iirc all facelift models will auto reset the stereo as long as its with the correct paired car. You'll be fine mate.
  1. steering wheel removal help
    By Даниил in forum Styling
    Last Post: 18th April 2012, 21:32
  2. Steering wheel removal
    By jacko52 in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2011, 20:05
  3. Anyone help me out with removal of vxr steering wheel please!
    By richiem in forum Vectra C / Signum Troubleshooting
    Last Post: 24th June 2011, 21:31
  4. steering wheel removal
    By pmw123 in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2007, 16:20
  5. Steering wheel removal??
    By alid32 in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2007, 19:25
