Results 1 to 10 of 20
Thread: guide for changing top mounts
    Feb 2012
    Kent
    Default guide for changing top mounts
    I found it once before and need to print it off to do the job
    Spent the last 20 mins on search but cant actually find the guide with photos someone put on
    Anyone know where it is?
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Not a clue where it is but basically jack up and support car
    remove wheels
    undo drop link top nut
    move brake pipes/ abs wires away from strut
    remove the 2 18mm bolts from strut
    remove the Tory bolts from top
    Pull strut out put spring clamps and compress spring
    Remove top nut (May need to hold strut using torx/ Allen key depending on design)
    pull of top mount and bearing
    replace with new one
    Rebuild is reversal
    Test drive
    Feb 2012
    Kent
    Seems pretty straight forward
    thanks
    Regular Member Signumv6man's Avatar
    Suffolk
    Trim : Elite Auto
    Engine : 2.8 V6 Turbo
    Quote Originally Posted by scw02102 View Post
    This is the one for changing springs - just don't change the springs !!! this how-to is SUPERB, job was easy and I completed in around three hours (total for both sides).
    http://www.vectra-c.com/forum/showth...t+coil+springs
    Steve C (signumv6man)
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    9 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 210,022
    My front suspension has been making an initially indistinct but now increasingly distinct 'spring-like' twanging noise. It's been doing it for some time and I haven't been able to devote time, effort and money to fixing the problem - until now. I have a series of questions. (1) Is it likely to be the strut bearings and / or mounting bushes? (2) Could it be the ball-joint at the lower end of the strut? (3) Since the car has been making noises for some time, will I need to replace the insert too? Thank you in anticipation. Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Quote Originally Posted by GSiFan View Post
    will be either , top bearing or broken spring
    9 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 210,022
    Ok. The springs are Eibach Sportsprings. Hopefully it's not those. Cheers, Mark. Are the bearings difficult to do? I still need to do my CV joint gaiter too. Been a bit slack about the Vec of late but feeling the love again, following a puncture today! (Eh?) Should I do the bushes / mounts at the same time? Paul
    9 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 210,022
    Oh, and where is a good place to buy them from? Cheers. Paul
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by Critch View Post
    remove wheels
    Rebuild is reversal
    Test drive
    Its best to crack the top nut while in situ, before removing the strut - far (and I mean far) easier that way
    9 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 210,022
    ^^ That makes a lot of sense to me. It's supported and held fast by the mass of the car body. Thanks for the tip! Paul
  1. rad mounts
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2009, 22:50
  2. rad mounts
    Last Post: 11th December 2008, 13:42
tips for changing the top mounts on a vauxhall vectra c
vectra c top mount bearing failing
vectra c do i need to undo the bottom ball joint to change strut
vectra c top mount
replacing top mounts tips
vauxhall vectra suspension top mount
how to remove top nut vectra c struts
how to change top strut mount on vectra
