Results 1 to 10 of 15
Thread: Brake servo pipe Help (Plastic Pipe)
    Regular Member Mark2.2's Avatar
    Feb 2006
    North East Uk
    Default Brake servo pipe Help (Plastic Pipe)
    I have a 2005 Vectra Sri Turbo and my brake servo pipe has broke on the valve thing, thats connected to the brake servo pipe. I tried phoning Vauxhall up but they said that pipe comes in rollls. How can it come in a roll when it's shaped? It's hard plastic with bends in it. This pipe has 5 parts to it with valves and connectors along parts of the pipe work. It comes from the brake servo to the battery area. The part thats got me beat is how do I get any old parts off the pipe work, the other bits are in solid. Without this part my car is off road . Thanks for any help / info
    The part in the picture is what snapped off....
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    I'd pop into a main dealer and make them look it up in front of you as they've obviously got the wrong part, by the sounds of it they've probably just looked up brake pipe
    Feb 2006
    North East Uk
    I wonder if the different pipe sections have part numbers? If I can get the old snapped end out I could probably just pop in the new part thats broke in the picture.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Your the second person this week to have this issue. You need a new non return valve, #90498464 Personally I would try pouring hot water over the pipes, or even immersing them in hot water, maybe wrap a cloth around it to help retain the hot water, and hopefully the heat should soften the pipe enough to remove the broken bits.
    There are a couple of vacuum pipe assembles on the link below.
    http://www.opeloem.com/vauxhall/vect...cuum_pipe.html
    Regular Member STICKY3.2's Avatar
    Jul 2010
    Hertfordshire
    I bet that's running like crap & no servo action on the brakes!!
    Jul 2010
    Hertfordshire
    You can replace the valve, heat the pipe ends with heir dryer to soften, pull out old valve, re heat and push new valve in.
    Feb 2006
    North East Uk
    I have found a valve from a breakers yard, are all the valves the same? The one I have has a different part number on it but it looks the same as the broken part
    Engine : 1.9 CDTi
    Its just a one way valve.
    Nov 2010
    East Midlands
    Trim : design
    Won't hurt to try it - but make sure it is the right way round or else your servo will not work - as above warm the pipe up with a hot air gun and it will go softer and allow you to remove the broken valve - when yo have the valve off you should be able to blow through it one way but not the other - check your scrapyard valve and make sure it goes on the same way as the original.
    Feb 2006
    North East Uk
    Well I have it all fitted up, the brakes seem ok on the driveway. I might take it for a little run in 5 mins to see. I bodged in a second hand one way valve from a salvage car (None Turbo).
  1. coolant hose replaced with plastic pipe from bnq??
    Last Post: 21st February 2013, 22:37
  2. brake pipe help
    By john1 in forum Suspension, Wheels & Brakes
    Last Post: 13th October 2012, 08:00
  3. vectra c brake/air pipe?
    By stuhack in forum Suspension, Wheels & Brakes
    Last Post: 3rd May 2012, 19:14
opel Vectra brake parts servo pipe with valve
servo pipe vectra
vectra c brake servo one way valve
servo brake pipe vauxhall
Vectra C brake servo pipe
