Results 1 to 2 of 2
Thread: Gear change hesitation between 1st & 2nd SRI 1.8 2007 Model
    Apr 2012
    Glasgow
    Default Gear change hesitation between 1st & 2nd SRI 1.8 2007 Model
    Hi. SRI 1.8 2007 model fully serviced (Oil & Plugs) and with K&N panel filter with box mod. Issue is it seems to drop the revs when changing from 1st to 2nd gear. it hesitates badly unless I accelerate hard in 1st then change in to 2nd when the revs are high.
    Its not a turbo model and any one advise if there is some things to check first? Car drives ok with out any other issue.
    Apr 2012
    Glasgow
    Just to update as no one seems to have had a solution. I fitted an Ecotek valve to the car and it has definatly made it better. Hesitation is not as bad and considerably more smoth in 1st and 2nd gears now. Used the Servo pipe. Hope this helps anyone else.
  1. What Oil Vectra SRi 1.8 Z18XER 2007 Model
    By shammon in forum Engine & Drivetrain
    Last Post: 11th May 2012, 01:41
  2. Model Year 2007 onwards - Front spring failures?
    By I cdti in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2012, 21:28
  3. New model gear stick
    By raymie.d in forum Styling
    Last Post: 30th June 2010, 08:23
  4. emissions light just come on 2007 1.9 sri cdti 150bhp model
    By Preey in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2008, 22:22
  5. Noisy Air Con 1.9cdti 2007 Model
    By CHRISSMART41 in forum Engine & Drivetrain
    Last Post: 13th October 2007, 00:57
