Thread: Vectra C 1.9 CDTI Automatic Problems - Engine & Gearbox
    West Mids
    Default Vectra C 1.9 CDTI Automatic Problems - Engine & Gearbox
    Hi,
    Brought a Vecci 1.9 CDTI Elite the other day, hoping to have a nice motor to creep around in, however doesn't seem like its not meant to happen.
    Any advise would be great, more positive the better!
    First issue:- When the car warms up, the gear change from 2nd to 3rd is very rough, revs freely, and then knocks into gear.
    A little bit of advise I have had, is that the gearbox oil is low, and when the cars warm, the oil thins and can cause this.
    Second issue, there is a misfire when cold on tick over, when rev'd feels like theres no power there, when warm the car drives bang on, other than the gearbox issue..
    no engine management lights, spanner etc..
    Other than that I love the car!
    West Mids
    No one?
    Regular Member Mopar Man's Avatar
    herts
    You need to do the wiring loom mod, on injector number three. Sorry but the gearbox sounds like its on its way out, you could try and change the oil and putting some conditioner in it. Get it plugged in first to see if there are any fault codes regarding the box. Could be why it was for sale.
    Regular Member Exclusive BV's Avatar
    West Midlands
    get the gb oil topped up first, whilst that is being done, check the drive shaft seals for leaks
    run that for a bit and see how it feels
    edit:
    sometimes the selector for the gears can wander. look in this thread
    http://www.vectra-c.com/forum/showth...=gear+selector
    herts
    If the gearbox oil was low it would be slow to engage gear when cold. The oil level rises when hot.
    West Midlands
    that's not been my experience with other cars but i'll bow to experience on these.
    In other cars i've had, the gear selection has been ok when cold and once warmed up it's got a bit clunky and you can hear it rumbling if the level is a bit low
    depends on the box and oil i know
    herts
    The gear change will be better before the oil thins out HOT on a worn box.
    Regular Member Vectra Meldrew's Avatar
    Hertfordshire
    I'm afraid the gearbox issue with harsh changes (particularly 2nd to 3rd) is quite a common problem on these and is usually wear in the valve block inside the gearbox. The part alone costs £800 plus big labour costs. If there's any way you can get your money back I would advise you to try, however if you do keep the car you may find you can cope with driving it carefully using the manual gearchange - I drove mine like that for 40,000 miles!
    West Mids
    Quote Originally Posted by Mopar Man View Post
    This is what i was hoping for, not worn bits as said in another post, thicker oil?
    As said when the car is cold, for a good 25 minutes the gearbox was fine!
  1. Vectra C 2003 - 2.2 Liter Petrol (Z22SE): Automatic Gearbox Oil
    By Tigra16V in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2013, 14:14
  2. Vectra automatic gearbox fiasco
    By brandon_fxdbi in forum Engine & Drivetrain
    Last Post: 12th January 2012, 20:17
  3. Vectra C 2.2cdti automatic gearbox filter
    By vectrac22cdti in forum Engine & Drivetrain
    Last Post: 18th April 2009, 20:45
  4. HELP! Automatic gearbox problems
    By dracunciliasis in forum Engine & Drivetrain
    Last Post: 14th May 2007, 21:48
vauxhall vectra automatic gearbox faults
vectra automatic gearbox problems
vauxhall vectra c automatic gearbox problems
vectra auto disel problems
https:www.vectra-c.comforumshowthread.php168189-Vectra-C-1-9-CDTI-Automatic-Problems-Engine-amp-Gearbox
vectra cdti 150 auto gearbox
vauxhall vectra 1.9 cdti automatic problems
opel vectra gearbox problems
vauxhall vectra 1.9 cdti automatic gearbox problems
vauxhall vectra 1.9 cdti automatic review
vectra cdti 150 automatic gearbox slipping
vectra c auto
1.9 cdti auto box capacity
vectra autobox not working in manual
vectra 06 auto not going in gear
vauxhall automatic gearbox problems
vectra disel automatic gpes into high rev and change gear with shuntchanges gear
automatic gearbox vauxhall vectrare con auto gearbox for 2005 vectravectra c cdti no drivevauxhall vectra exclusive cdti gearbox fault2005 vauxhall astra 1.9cdti automatic gearbox problemsvectra c 1.9 cdti automat problemvectra c automatic problemszafira b automatic problems
