Results 1 to 3 of 3
Thread: You opinion on my warranty work/fault
    Regular Member Craig1985's Avatar
    harwich essex
    Default You opinion on my warranty work/fault
    Had the car in for a service at 30k and mentioned that when the steering lock is on and you wiggle the steering wheel there's a slight click/crunch from the lock area. ( fine when driving )
    Network Q have authorised a cim unit and I have got to take my car pass in when it has the work done. Does this sound right??? I thought the cim controlled the electrics to key and dash?????
    Network Q will authorise the work as submitted to them by the dealership
    Whether it is right or wrong will only be found it once the work is carried out
    For a replacement CIM, this procedure is correct, and requires the Pass Card (if not already on the dealership records for your account) and both keys
    The CIM is the entire unit that sits hidden behind the steering wheel, and you can see where the key enters
    If it is only making noises why you insert the key, then it does suggest the casing of the CIM has split
    harwich essex
    Ok I didn't realise that was a whole complete unit. Glad I'm not paying for it! Thanks for the reply.
  1. Replies: 15
    Last Post: 9th July 2011, 22:19
  2. warranty work paper work ???
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2008, 00:21
  3. Warranty Work!!!
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2008, 18:43
  4. How much warranty work have you had done
    By willc01 in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2007, 17:57
  5. Warranty Work
    By DarrenLee in forum General Chat
    Last Post: 27th April 2007, 19:52
