Results 1 to 10 of 23
Thread: Fuel Filter and Spark Plugs
    Regular Member Fitzy-2.0T's Avatar
    Hertfordshire
    Default Fuel Filter and Spark Plugs
    Hello guys going away in 7 days and was going to book the car in for a service then I thought no I wont be lazy I'll do it myself all the other filter changes and oil changes are fairly straight forward.
    I want to change the fuel filter and also the spark plugs, firstly where in the fuel filter located I own a 1.8 Petrol 52 Plate, how easy is it to change the spark plugs?
    Any help or guidance is always much appreciated.
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    SPARK PLUGS (VVTI but should be similar if not same?) - http://www.vectra-c.com/forum/showth...ugs-On-1-8-VVT
    AIR FILTER - http://www.vectra-c.com/forum/showth...n-1-8-vvti-mod
    OIL (VVTI but should be similar if not same?) - http://www.vectra-c.com/forum/showth...-Filter-Change
    FUEL Filter - I think thats under the rear passenger side wheel arch...
    Hertfordshire
    On my car the oil filter is accessible from the top, plenty of space and it just looks like a normal crew on filter no housing.
    Barrow In Furness, Cumbria
    I think the only difference is on old models, the drain plug is in a slightly different place on the sump (could be the front?) and the oil filter is a different type.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    fuel filter is under the car, approximately under rear passenger seat on the drivers side.. jack up the car to see it..
    whilst you want to do the oil change after the engine has been run, you do not want to do the spark plugs then as they will be too hot. Also the fuel system will be pressurized so not a good time to do the fuel filter as you will get a face full of petrol..
    Regular Member sheepish's Avatar
    Yorkshire
    As long as your car isn't lowered you can do the fuel filter quite comfortably without jacking the up.
    Hertfordshire
    Hello guys thanks for the information, does anyone have a picture of the fuel filter on one of these cars might be a little easier to locate. Should I do the fuel filter and sparks first then?
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Here is a thread on changing the fuel filter.
    http://www.vectra-c.com/forum/showth...06#post1102206
    Hertfordshire
    Thanks great info on replacing the fuel filter, what's the best brand of oil filter to get?
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    VX are as cheap as ebay and motor factors. I paid £3.16 last time I bought one.
  1. Replies: 0
    Last Post: 24th January 2013, 18:50
  2. Spark Plugs
    By lizard in forum Petrol Engine related
    Last Post: 4th April 2010, 10:36
  3. Spark plugs
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 14th September 2009, 01:34
