Results 1 to 10 of 11
Thread: Beep when i set off.
    Jul 2012
    scarborough
    Default Beep when i set off.
    My 05 vectra cdti sometimes beeps when I set off. It doesn't do it everyday but if it does it once it will do it everytime until you switch it off and restart it. Any ideas?
    Essex
    Do you have your seat belt on or happen to have anything 'heavy' on your passenger seat when this happens?
    Jul 2012
    scarborough
    I and all my occupants always wear a seatbelt. It only beeps once but everytime you stop then pull off again. I will try it with the seat belt unplugged and see if its the same beep. Thanks
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Check the boot catch.
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    handbrake fully released?
    Regular Member Dai69's Avatar
    Nr Welshpool
    Vehicle : Vec C Estate X 2
    Engine : CDTi 150
    Year : 55&56
    Mileage : MANY
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    ill go with handbrake
    similar thread here
    http://www.vectra-c.com/forum/showth...fully+released
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by Neve'o View Post
    If it's one notch up, it will beep when you hit about 8-9mph
    11 Post(s)
    Quote Originally Posted by tony-1977 View Post
    But the OP says he only hear's one beep. IIRC, you get a continual beeping if the handbrake is still on.
    My bet is a door or boot isn't closed properly, or the switch that monitors door/boot is faulty as that's about the only thing that gives one beep if left open or ajar.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I'll read threads properly next time
  1. Beep Beep Beep
    Last Post: 31st December 2009, 21:32
  2. Annoying beep!!!
    By stubopvectra in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2008, 19:44
  3. Beep or Bing noise
    By Perry in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2007, 23:53
  4. alarm arming 'beep'!
    By kojak01 in forum Electrical & ICE (including SatNav)
    Last Post: 21st February 2007, 23:36
  5. Vrrrrooooooooooooooom! Beep Beep!
    By ukanalyst in forum Quick Photo Album
    Last Post: 6th February 2007, 23:15
Vauxhall insignia seat belt beeping when seat belts are worn
vectra c beeps once when started
