Thread: Fault code help!
    Jun 2012
    Thornaby
    Default Fault code help!
    Just done the pedal trick after reading it on here.. (car has airbag light on so thought that would show up)
    That didnt show up.. but i got the following:
    0530
    1565
    any ideas what these could be and how to sort them? Did a search but couldnt find a definate problem.
    Cheers!
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I could be wrong but I believe 0530 is related to A/C pressure
    Jun 2012
    Thornaby
    Thats what i got when i searched it.. thanks for your reply! Il have a ring round a few garages tomorrow see how much itl cost ! Arm an a leg probably!! Need that airbag light off too!
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Fault codes are as follows: -
    P0530 A/C Pressure Sensor Circuit Low Input Heating, Ventilation and Air Conditioning System C-009
    P0530 A/C Pressure Sensor Circuit High Input Heating, Ventilation and Air Conditioning System C-009
    P0530 A/C Pressure Sensor Malfunction Heating, Ventilation and Air Conditioning System C-009
    Regarding the other code, the nearest I could find was: -
    P1560 System Voltage Malfunction Power Supply and Communication C-113
    The most common problem with the air-con circuit is when the condensor becomes pin-holed, and loses pressure.
    The usual fix is to replace the condensor and the receiver-drier.
    Typical factors price is about £130
    Fitting depends who does it for you, but it is basic plumbing.
    Then a vacuum and regas should cost about £50 to £60.
    Ensure that who ever regasses the system, that they fuly vacuum out any moisture and contaminents, otherwise premature component failure will occur.
    A decent regasser will always vacuum the system first.
    However looking at the fault codes, I would say that there could be a voltage supply issue.
    Faulty fuse / relay in the UEC (engine bay fuse box), or a dirty wiring connector.
    When I lost all my refridgerant, I did not get any fault codes.
    My air-con just stopped working.
  1. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  2. Fault code help!!!
    By billy88 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2011, 16:02
  3. help with a fault code
    By jan65uk in forum Engine & Drivetrain
    Last Post: 15th December 2009, 20:57
  4. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
vauxhall signum p0530
