Results 1 to 10 of 25
Thread: Bad time for the vectra :(
    Jul 2011
    UK
    Year : 06
    Default Bad time for the vectra :(
    Well missis pick me up from work and I drove went round a corner heard a bang from passenger side thinking nothing of it went round another corner bang ok wtf carried on went over bumps nothing went over another bang **** got home and the car is sitting lower on passenger side so spring must of gone **** lol
    Oh oh looked at rear of the wing near rear light and some heartless poo head has keyed the car around 5 inch so need get da out
    So the big question am on budget so will lo 45mm front and rear springs be alright for 89.50
    Jul 2011
    UK
    Year : 06
    Is this the Problem seem like a chip
    Nov 2010
    East Midlands
    Trim : design
    Can't really see from your picture Marc - but you will have to stop biting your nails ..... lol
    Jul 2011
    UK
    Year : 06
    Lol yer I know am bad at that on the pic the next to the shocker there is a hole around a inch big
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I think you might find its the top of the spring that is broke
    Jul 2011
    UK
    Year : 06
    How can I find this out with it on the car just stick my hand up there lol
    Northampton
    Engine : A20DTH
    Mileage : 88000
    You should be able to see the spring at the top with the wheel off. It tends to break at the top and a small bit falls off and can end up sticking in the well or left behind on the road. Check your tyre for damage just to be on the safe side.
    On the subject of 45mm springs I think they would be a bit much for the SRi shock and would ideally be beeter with a shorter shock such as a B6/B8 Bilstein. I would not use any springs that go that low on the standard shock. Best getting 30mm Eibach ones, they are a bit more money but have a longer warranty and will work well on the SRi shock.
    There will be other members that sat 45mm is fine but then I don't they realise how badly their car can handle
    Barrow In Furness, Cumbria
    Jack it up so you can see it better. Spring will probs wobble around as the shocker is fully extended.
    Jul 2011
    UK
    Year : 06
    Cheers guys I got measuring tape front the centre ground to wheel arch this is what I found
    Drivers side
    Passenger side
    Edit didn't work first pic drivers side second passenger
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yep looks like the top bit has broke off
  1. Time for the vectra to go.
    By redross555 in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2013, 18:59
  2. vectra is gone---- is it time for a bmw smg
    By chrisgettings in forum General Chat
    Last Post: 13th March 2010, 12:02
  3. Time to get rid of the Vectra
    By FuzzyOne in forum The 'Off Topic' room
    Last Post: 8th May 2009, 19:54
  4. vectra c time
    By swainey in forum The 'Off Topic' room
    Last Post: 1st March 2009, 22:35
  5. Why did you not go for a Vectra this time around?
    By John C S in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2008, 21:06
